rexman72
pulley for pump
rexman72
what do you guys recommend for a pulley for my loader pump.I tried a pulley with a set screw which was to big for the shaft where the keyway goes into the hole.The keyway hole is 1/16.so I am trying to find a pulley with the keyway that will fit on the shaft?any thoughts?
benji756
if you can't find a pulley with the right keyway you can have the right size keyway broached in the pulley or make a step key that fits, I have done both.
rexman72
so where do you usually get your pulleys?you mean fab up a step key to fit?
daveoman1966
I have a box of generic pulleys with keyways in my shop.  Questions:
Outside diameter?
Shaft size ?
Find me at this email address:
daveoman@windstream.net
benji756
yes I have access to some machining equipment at work so I have made step keys before, if I need a keyway broached I take it to the tool room and have it done.
