northstar714
1960 suburban H55B
northstar714
Hello guys need a little help on factory carb settings for Tillston E2. Just need to know where to start. 5.5 Lauson starts but floods out. Clean plug and fires again for about 30seconds. Please any help would be appreciated.
KC9KAS
@northstar714 Try this.
  • Similar Content
    • hotajax
      By hotajax
      Morning -  Looking for a carb.  There are plenty of carbs on the 'net, but 99% do not fit because of the choke configuration.
      Background info:  Engine - K321S, 14 Horse Kohler.
      Choke control cable is routed to come from BELOW the carb.  To close the choke, pull on the choke knob, the choke shaft rotates counter clockwise, and the finger tab sits at the 10 o'clock position.
      To open the choke, push on the choke knob, the choke shaft rotates clockwise, and the tab sits at the 1 o'clock position.
      Where can I get his carb?  Thanks in advance.
    • 67 WH 877
      By 67 WH 877
      When I purchased my WH (67 T877) it had the incorrect oil bath filter on it (it bent the front of the grill out) I took it off and placed a regular filter using just the oil bath cover. My question is...is it ok to run these Kohlers without the oil bath filters? I know they are better filters, but Im curious if the modern filters are sufficient.
    • r1jakecfd
      By r1jakecfd
      Hi Guys,
      I’m cleaning the Onan P220 carb on my 520H. It’s a Nikki 146-0479 carb. I was wondering if the main jet needs An o ring and if so which type and size? There was no o ring when I took it apart.
      Thanks!
      John
    • Seacrestbf
      By Seacrestbf
      Hello, I have a D 200. It has been running great, I was having a hard time starting it and I replace the filter and fuel pump. Adjusted the carb, and now under heavy load she will bog down and stall. If you are just driving seams fine, but if you tow a trailer with the mower, I boggs and stalls? Carb Issue or Fuel Pump?
      Thoughts?
       Thank you
      Brian
    • KC9KAS
      By KC9KAS
      Looking for the correct carburetor number for a Tecumseh H60-75063B on my 654. This is the correct engine & model number, but I can't determine the carb number so I can buy an aftermarket carb.
      Thank you!
