Detector
Photo needed of 1990 312-H or 416-H brake pedal
Detector
Looking at partstree I'm missing a spacer and washer behind my lift cylinder that is mounted on the same shaft as the brake pedal and I'm not sure if the brake pedal spacer I have  "Toro 107691" is correct, cannot find a photo of it. I have nothing behind my cylinder. Any pic would be appreciated
rmaynard
I don't know if this will help you, but here are some pictures of my '96 416-H brake pedal/lift cylinder setup. This is the only way I could install the hardware to keep things lined up and not rub.
From outside to frame, in that order:
Edited by rmaynard
Detector
Yes very helpful & Thank you for taking the time to take the pics!! Everything on mine lined up fine prior to dissambly and I see no wear on the cylinder closest to the frame so I may roll with it like it was prior to disassembly.
