Adam Bish
C160 transmission oil seals
Adam Bish
Can someone here please tell me if the brake shaft, input shaft, and axle seals are still available OEM for these 8 spd. gear drives?
pfrederi
Axle  100443
Brake 100441
Input 100442
Look at the pinned post top of this forum for conversion to CR/SKF and National seal ###
rmaynard
Toro parts are made of plastic. The after-market replacements from NAPA are made from steel and are usually less expensive as well.
Adam Bish
thank you
