Chas520H
520H hydro
Chas520H
I have a 520 H and getting ready to change hydro tranny fluid and was wondering? Manual says high quality 10 w 30 motor oil and not transmission fluid as I would have thought? Also is the hydraulic lift for the deck and attachments and hydro trans all one unit or do I need to service the lift unit separate as there is nothing in regards to this service in my manual which is the original manual from purchase?
Edited by Chas520H
Add picture's
squonk
All 1 unit. Use Mobil 1 10w30 and a Napa 1410 filter. Remove 1 of the bolts on top of the trans that hold the rear lift cable tube on so the air can escape when filling. These hydros are a bear to get the air out at times. Fill slowly stop at the add line and run the tractor around some. Let it sit a day  or so and top off slowly. If you fill it to the full line and there is still air trapped it can burp out qil when it gets hot and make a mess.
Chas520H
Thank you so much squonk! Figured it would be you that answered. See your name a lot on the forum
Chas520H
Is Mobile 1 a synthetic oil?
Edited by Chas520H
squonk
yes
