Countdown To Christmas!
Similar Content
By t_furl43
1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well, it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4 -
By Wayne Clark
I have restored a C-101. 10 HP Kohler - 8 speed - cast iron transmission with 36" deck.
Any ideas what I could sell it for. Thanks. Located in Imperial, MO.
By Pullstart
Jada decided she wants do drive the wheelhorses because her battery on the simplicity was dead. She can just reach the clutch pedals and I kept both the 502 and C-101 in low range so no matter what gear she selected it was still slow enough. I've created another monster!
click for short videos...
By Pullstart
So my mom gave us kids cash for Christmas and told us to go find something for ourselves, I took a little 50 some mile road trip this morning and picked up a steel fender C-101. Overall, it seems to be well taken care of and in great shape! Except for the connecting rod issue that I knew about before heading to get it. I have a spare 10 horse that had the carb and starter bits robbed from it before I picked up my 8 speed donor for the 502 so I should be able to use the left overs to get this back running. Came with a RD deck and a big folder full of service records and receipts. All in all, this will be a worker and should give me the ability to refresh my 502 without the worry of downtime!
By Pullstart
I just replaced the 3 speed transmission from my 502 with an 8 speed from a C-101. the brake band location is different and the 8 speed brake bearing is loose, making me want to tear it apart. Is there any confirmation that the only difference of these two cases is that tab? could I put my 3 speed LH case on the 8 speed transmission, or is there more bosses in the hi/low case? it would help prevent leaking oil and help to keep the brakes all set up right.
thanks!
