classicdmax
Tow valve?
classicdmax
I know it is not best practice to push a hydro around. I've searched owners manual I printed from this site, as well as tranny manual....it seems it's on the left side but actual location is vague to me. I have a 73 16h hydro. The no name year I believe.
any help would be appreciated
thanks
953 nut
Take a look at item 6 on page 5 of this manual
Sunstrand Hydro (part 4).pdf
It is under the seat on the left side top of the trans and will require a 1/4 turn, may need a pair of pliers.
Aldon
For Easley reference I cropped the pic from the manual:
swisstrac
On  the gt 14   I do 1/2 a turn??  perhaps 1/4 will do .. as you say it's not  easy to access
Aldon
180 degrees is the dictated amount to turn.
make sure when your done you return it to the original location. Otherwise you will end up like me thinking you did not connect something correctly. DOH !!!!
daveoman1966
If a 16 Auto...no-name year (1973), the push / tow valve is on the left side.... It looks like a BIG SLOTTED screw.
  • Like 5
classicdmax
That last pic helps, thanks guys. I'll check it out tomorrow
TDF5G
It's harder than %^&*#! to get to, I know that.  :-( Very poorly engineered IMO.  I was fortunate that mine wasn't' frozen up.
Wheelhorsegt14
What is the correct position for the push valve?
Edited by Wheelhorsegt14
daveoman1966
Turn the PUSH valve clockwise until it bottoms out.
classicdmax
Is it possible to weld a tab to end of this valve to aid in operating push valve. I haven't yet had the need to push the tractor, but have tried to open valve and it seems to be frozen
pfrederi
The heat from welding could damage the O-ring and the plastic backer ring then you will have more problems.  Soak it with your favorite rust breaker over a period of time..tap it and try again.
classicdmax
Ah good thinking, wasn't considering any of the seals
its not a very practicle design for easy operation. You shouldn't need tools to release pressure for pushing or towing
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • BrianKoch
      By BrianKoch
      Gentlemen,
      According to the hydrogear transmission manual, the tow valve on the ‘69 Charger 12 with the Sunstrand 90-1136 is “malfunctioning” because I am able to roll the tractor while it is closed.
      To note, the parking brake pawl also seems to be broken, but I believe these issues are independent of one another.
      Have any of you dealt with this issue of a malfunctioning tow valve before and can advise? I’ve got the ATF drained out and would like to address this before refilling.
      As of right now, I have removed the tow valve and attached a picture of it. The O ring and nylon washer look fine to me, but maybe you see or know something different.
    • Thatoneguy
      By Thatoneguy
      So I washed my rear end and sundstrand 90-1136 and now the by pass valves leaks when I screw it in past a certain point.  If I screw it all the way in I can sit there and watch the fluid start seeping past it.   I changed the o-ring with an R-04 i believe is what it was.   Do these require some sort of thread sealer? There was nothing on it when I took it out, and when I used the valve to push the tractor in my shop it worked fine and has never leaked. Any ideas would be wonderful!
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
