DennisThornton
GT 14 tear down to replace rear axle bearing
DennisThornton
Got a chance to buy a 1970 GT14.  Appears complete but no 3 point linkage at all, which does concern me.  Also needs the rear axle bearings replaced.  I really need yet another project that I can't possibly get to!
How long to replace those bearings on a GT14?  And am I right in thinking that since I hardly ever see a GT14 for sale around here that I'll NEVER see the 3 point parts either?  I really don't need a GT14, but what the heck does that have to do with anything?  My only small 3 point tractor is my PK.  Then again I don't have any small 3 point implements either!  Only big ones for the TC-35.  Why would I even want another tractor for implements I don't have or need.  Insidious disease!  Oh well, please tell me that the GT14 axle bearings are impossible to replace or that it's just not worth it.
Thanks!
  • Like 3
Aldon
I've not changed the bearings. But it would be same as the other Sundstrands so you will likely find more info if you broaden your search. @953 nut showed that it's fairly straightforward modification to make other Sundstrands work in GT14.
if it's just the seals then that's easy.
As for 3 points, you don't see them often and when you do they are ~ 300 and almost never have the draw bar to use common lift cylinder.
A couple people are reproducing them.
Lowell, vendor @wheelhorseman1000that sells cables and stuff is planning to reproduce them. He is already reproducing selling the draw bar.
Did you pick this one up in my neck of the woods?
oldredrider
Thanks!
Dennis, Dennis, Dennis.  You're thinking out loud again! You want us to talk you out of something you want, not need. You came to the wrong place!  We are all addicts and enablers here.
I'll be the first to say: Get it!  Worry about the details later. We'll help you through this.
  • Like 7
meadowfield
Buy it!
I've got two, one with a home made 3 point - but then it did have the rocker and draw bar.
the trans split pretty easy, I had to replace a few bearings in mine when it arrived. I think my GT14 thread covered it
mark
  • Like 3
953 nut
Meadowfield's rebuild thread was what I have used as a reference while doing repairs on my Hydrogear. He and @refracman have a wealth of knowledge on this subject. You know you want it Dennis, go get it!
Aldon
If you decide to get it, we want a detailed thread on the axle repair! Lots of pics.
DennisThornton
I've never pulled a WH rear so I have no idea how long it would take. 'Course I have no time anyway so why would I even ask...
I'm guessing you are familiar with the one I'm referring to.  I'm hesitant because I'm thinking I might as well pay more for one equipped with the 3 point.
I really thought I could count on at least you to help me out of this! ;) I really don't need the darned thing especially without the 3 point!  Can't even use it as a yard tractor without replacing the bearings and seals!
Ahhh, what the heck.  I'm not worried about being able to fix it if I had time, what I am trying to find out is how silly I am to think I might have enough time someday!
So thanks guys but "how long" should it take to replace the axle bearings?  I'm guessing at least a half day,  Maybe more?
Aldon
Your first time tearing down the GT14 give yourself  half a day just to get to the hydro.
If if your looking at the one I think you are, make sure that it has the light and PTO switches. Especially the PTO switch.
if bearings themselves need replaced I think the fella is still a bit high.
wrightorchid
Get this one, and then when you find one with the 3-pt, keep the better tractor, and move the 3-pt if appropriate, then sell the extra.  There is always room for one more......
DennisThornton
@Aldon
I do appreciate your help though telling me it's a half day just to get to it!  Your a good friend! :)  I really don't need another WH just waiting for me to come fix it.
And I agree about the price.  But if he drops it again I'm not sure I can resist!  And if it had the 3 point, I'd be taking pictures of it in my truck!
I think I'm OK for now.  Thanks again Aldon!
I'm getting to the point, esp with winter coming on, where it's just not fair to the WH to not be able to get around to fixing them.  I'm trying to limit myself to buying attachments with tractors already attached to them.  I really don't need another yard tractor, or even a riding mower.  Now!  If it had a mid-mount blade!!
  • Similar Content
    • tractorboy79
      By tractorboy79
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
