Jacky B
Leaf Vacuum Help
Jacky B
Hello:  I'm a newbee here.  I'd welcome some help re. an older leaf vacuum housing & impeller   A tag on it appears to read "67-42VC01-12074.  This may NOT be correct to the part since it's had several owners.  The housing is ruined and I would like to see if replacement part(s) are available.  Can anyone verify the pn or recommend a source for replacement?  The impeller has only (2) blades and measures about 12 1/4" in dia.  Thanks very much for any responses.
        Jack
gwest_ca
Welcome to the forum.
Here is a parts list you can download
Enter a part number here to see if it is still available. If it comes up priced it should be available from any Toro dealer
https://www.partstree.com/parts/
Garry
JC 1965
Hello and    :WRS:
