blackwater73 8 #1 Posted September 1, 2016 What is the weight of this Tiller? Share this post Link to post Share on other sites
stevasaurus 22,706 #2 Posted September 2, 2016 Do you have a model number?? Did you take a look in the "Manual" section for a Manual?? That will probably have the shipping weight. If you are looking at shipping it...tell them it is between 80 and 100 lbs...that should be in the ball park. More information should get you a better answer. Share this post Link to post Share on other sites
blackwater73 8 #3 Posted September 3, 2016 I do not have the model number, I am going to try to buy it and I need the weight to see if I can handle it by myself.Thanks for the imfo. Share this post Link to post Share on other sites
BESTDOGEVER 218 #4 Posted September 4, 2016 That depends on how much you want a hernia or to have your back go out. Hard to grab, I wouldn't want to put one in a pickup alone into a trailer is a bit more doable Share this post Link to post Share on other sites
Forest Road 594 #5 Posted September 9, 2016 150-200lbs. I usually drag them around or use a hand truck. I've picked up several and placed them in my truck. Always better to have a helper. Share this post Link to post Share on other sites
clueless 2,975 #6 Posted September 10, 2016 On 9/4/2016 at 4:01 PM, BESTDOGEVER said: That depends on how much you want a hernia or to have your back go out. Hard to grab, I wouldn't want to put one in a pickup alone into a trailer is a bit more doable Share this post Link to post Share on other sites
