Rustyred
C-81 or B100 - To buy or Not to buy
Rustyred
C81 or B-100 To Buy or not to Buy
Hi guys. Yesterday I posted that I am looking for a fixer-upper for my son and I was looking at a C-161. Now it may but may not be available.
I have two other options. A C-81 in unpredictable shape for $300 (tractor only - no extras shown on picture below) or a B-100 with pictured blow (it runs) for $450. (I would hope to get the price down.)
The C-81 is being listed as an 8 speed with an 8 hp engine. The B-100 is listed as an 1976 8-speed with a 10 hp engine.
My question is - are they worth the price? Which would you buy for your kid to fix up? Does either one have a better record than the other?
We are not looking at mowing and likely not plowing. At least not to start. We would have a trailer and be doing landscaping projects.
Hopefully this post isn't too long but some pictures are below. The first 3 are the C-81 and the last 4 are the B-100.
THANKS
gwest_ca
The mower deck is much newer than the tractors and uses blades that are easily available. Blades from the tractor era are no longer available.
B-100 is 1974-1977
C-81 in 1978 or 1979
Both use 1-1/8" axles and 8-pinion differential.
Garry
953 nut
Judging by the pictures the C-81 is an honest worker that has been used but maintained; the B-100 looks a bit scary to me, not too well maintained and could be a problem child.   :twocents-02cents:
:WRS:
Edited by 953 nut
oldredrider
Get the C-81 and don't look back!
  • Like 3
russellmc301
c-81 looks to be more maintained and looks better.
Rustyred
Thanks everyone for your input. It is appreciated.
How would the C-81 do pulling a small trailer of lets say dirt, much, shrubs type stuff. Is 8 hp enough for that type of activity? Do wheel weights help for that kind of work?
953 nut
You will be amazed at what an 8 HP :wh: can do. For that matter the RJs and Suburbans had 4 HP and could pull a lot of weight.
oldredrider
Yeah, and they only sip gas doing it.
pfrederi
My Lawn Ranger will haul the coal wagon in the avatar that weighs about 750 lbs. You will run out of traction long before you run out of HP...even with wheel weights
wfrpalm
C-81 has my vote.
woodchuckfarmer
Get the C-81 its got a lot more goodies with it.
Racinbob
You could always put a 16 on it in the future. The C-81 and C-161 share the same frame and transmission and the swap is simple. But I'm betting that you would be happy with the 8. :)
Upper Canada
I have a Commando 800 (not the same tractor as c81 but same HP engine).  I was hesitant at buying it due to the smaller engine, but the fine people here at Redsquare convinced me to buy it.  I do not regret that purchase one bit.  You would be amazed what the 8hp engine in a :wh: can do.
I would buy the C-81.
Edited by Upper Canada
russellmc301
:text-yeahthat:i have an a-100 and it has a a 10 hp and the wheels spin before the engine bows down. i have pulled up alot. that was draging and in my wagon ive hauled it full of what ever will fit half the time i forget im pulling the trailer. the c-81 is my pick my b-80 pushes snow with ease.
N3PUY
I think Rusty said there are NO EXTRAS with the C81.
can whlvr
if the 161 comes available get her,you would like the 8hp but would love the 16hp
cafoose
I love my 8hp 876. I have pulled a 16 by 8 all steel diamond plate dual axle car trailer around the yard with it with no problem except for traction on grass sometimes going up an incline. I have also leveled a tri-axle load of topsoil, spread tons of driveway stone, and pushed eight to ten inches of snow. That little tractor surprises me what it can do. :banana-dance::banana-dance::banana-dance::banana-blonde::banana-dreads::banana-jumprope:
Rob R
Absolutely love my C-81 plows like a bear, maneuverable, starts easily, sips gas..... would never Wheel Horse C81 3.JPGpart with it.
DennisThornton
Love both my 8hp Cs!  All the power I need for snowplowing and running a 36" deck!  Like mentioned earlier, sips gas!
Rustyred
Well - thank you for all the input on which way to go with this. As soon as an purchase is made and we are proceeding my son and I will be depending on your advice!!
Again, thanks for the support.
  • Similar Content
    • Mattgray
      By Mattgray
      I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
    • TailGate18
      By TailGate18
      Need help please
      Can't exactly identify my wheelhorse. I believe I've pinned it between 74-79 but not sure exactly. I'm not real knowledged in mowers but interested in learning. It ran few years ago. Then parked in a storage unit for about 3 years with gas left in it. I can't get it to run at all unless using ether.
      I've drained all the old gas, I've replaced the fuel lines, new plug, new gas, but it just won't start up and keep going. I figured on new carb but don't know exactly what I'm looking for and thought I'd better know the exact details of the mower so I know I get the right parts. Any help would be appreciated. The info I do have is as follows.
      The mower itself all I could find was one tag on the frame under the gas tank.
      ID # 61-08K801-05782
      Then under that 4 digits
      6337
      Has a Kohler motor info as follows
      Model-K181
      Spec- 30538
      Displ (cc)- 305
      Serial #- 2613800539
      It'll crank but not start. Not even attempt to start. With the fuel line off of the fuel pump it shows it pumps fuel. I thought the possibility of the float being stuck in the bowl but again not very knowledged in this field. Would appreciate any insight, details, knowledge, help or anything of the sort. Or info on the information of the tractor so I know exactly what I'm asking questions about
      Says it's a B-80 8 speed
      Thanks in advance
    • nickjet67
      By nickjet67
      Hello all, I recently acquired a "new" B-115, and with the help of @ohiofarmer, I will be fixing her up, first with a engine he is trading me for my old Kohler engine off my '77 B-80 that I trashed when I was 13. I haven't been in the Wheel horse game long, as I am 16 now, I hopefully will be able to keep this project updated on here, especially in the spring when I will be completely repainting it! I am super excited for this project, and am ready for all the challenges that lay ahead with it. if you have any helpful information you are willing to share about my newly acquired project, please share! I haven't had tons of luck finding tons of information about it.
    • nickjet67
      By nickjet67
      Hi, been a while since I been on the forum, but I needed to log on to get some help with my "new" b-115 I picked up for $25! I saw this beauty sitting on the side of the road and I just needed to have it. only issue is it doesn't have a engine and the steering was all discombobulated. Last night I got that all welded up and now I am looking for help, I need to get the Briggs motor that came on it now, I have had 0 luck with finding the right motor for it but I have found almost every part I would need to build one from scratch. They are all over ebay and craigslist (the parts) and would be expensive but nice. Any help would be greatly appreciated! (also am looking for a snow blower and a bagger for it, dont know if the bagger for it exists but would be nice to have.
    • dmhill
      By dmhill
      Does anyone know what drive belt and deck belt I need for the 1980 B 82? Also if anybody had pics of the drive belt installed I would appreciate it.....
      When I picked it up both belts were/are missing. Not entirely sure all the necessary hardware is under there either, however, it seems complete. Thank you in advance.
