oneshort 4 #1 Posted August 31, 2016 Hello all; I have a 1966 model 876 automatic drive with the sundstrand 3100077 transmission. while repairing it i lost one of the " round wire" snap rings that holds the gear motor gears in place.I can find numerous diagrams of the piston pump but none of the hydraulic drive motor. I have been unable to find a part # for the snap ring. I'm hung -up! Thanks for any help! oneshort Share this post Link to post Share on other sites
953 nut 55,909 #2 Posted August 31, 2016 If you measure the outside diameter of the shaft and go to Ace Hardware or NAPA they will fix you up. Share this post Link to post Share on other sites
pfrederi 17,910 #3 Posted August 31, 2016 WH didn't consider the hydro gear pump to be serviceable...it was repair by replacement Share this post Link to post Share on other sites
wallfish 17,084 #4 Posted August 31, 2016 maybe this helps http://www.americanring.net/products/rings_constantsection.aspx 1 Share this post Link to post Share on other sites
