rmaynard
416-H/ARK Loader Fitment Issue
AMC RULES
:woohoo: Nicely done Bob.  :greetings-clapyellow:
dclarke
I knew you'd figure it out, Bob.... Good job!
mmmmmdonuts
Nice job. That loader will be up and running in no time.
DennisThornton
I knew you could do it!  (But I thought you were going to need more help!)B)
Great job!
roadapples
Nice neat job. Sometimes you just need to get away from a project for a while. Then it comes together and you wonder why you couldn`t see it before...
ACman
Way to go Bob :handgestures-thumbupright:  ! I knew you could do it  :text-woo: .
rmaynard
Thanks for all the encouragement. I think this thing is going to work. :handgestures-thumbupright:
  • Like 5
roadapples
As you said, that 520 axle will add a lot of room...
wrightorchid
Fantastic.  Always great to have more eyes look at things and get more ideas..  A little paint and it will look almost factory.
rmaynard
UPDATE - Today I picked up some new hoses and a couple of o-rings. Denny Clarke gave me a bag of large o-rings in case I needed to rebuild any of the cylinders (thanks Denny), but I needed four one inch o-rings which act as oil seals around the 1" shafts. I knew that one of the cylinders was bad, but I didn't know which one, so I rebuilt all of them. Not hard, just time consuming. So six hours and 16 o-rings later, all the cylinders are rebuilt and back on.
So, the moment of truth...does it work?  Stay tuned for the rest of the story.
  • Like 4
82Caddy
If one of your lift arm cylinders is scored or leaking, let me know I have a single good one from my ark loader.  I replaced/upgraded mine when I couldn't get one to seal again and a replacement shaft was $$$$.
rmaynard
Thanks for the offer. So far, so good. :handgestures-fingerscrossed:
ACman
:text-bravo:Way to go Bob !
dclarke
Looking good, Bob. :thumbs:
Ed Kennell
Made me think of Ralphie  when he opened that Red Ryder B-B gun in the Christmas Story.      WTG Bob.
roadapples
Now you can sell your wheel barrow.... You`ll wonder what you did without it.. Good job Bob !
WHX??
Your not helping my addiction,:lol: some weights, that swept axle you'll be in like Flint Bob!
Another vid of it doing work is now in order! :greetings-clappingyellow:
Forest Road
Looking good! Add 300-400lbs ballast and  a pair of ags out back and you're in business.
rmaynard
Working on a ballast now. No AG's for me.
rmaynard
Onto a new subject. Does anyone have experience rebuilding or repairing one of these?
Everything seems to work fine until I push the lift control too far forward. Instead of returning to center when I let it go, it locks as shown in the next image. I have to physically pull it back to keep it from lifting the front end of the tractor. It actually snaps as I pull it back like it is hanging on something. Any help would be appreciated before I tear into it.
wallfish
It's designed that way as a float detent, but the cylinders should not be moving by hydraulic pressure. They should float, which allows the bucket to follow the terrain of the ground.
Edited by wallfish
rmaynard
Hmm, I will check it again. I may have been operating it incorrectly. Thanks John.
wallfish
It does take a little getting used to by not engaging the float when applying down pressure but it becomes very useful when grading the ground. I back drag the bucket in that float position.
MalMac
Yep, it's a float postion. Like said very useful. When I park mine when done I'll use float postion just to take any pressure off, so if there are any leaks they don't have pressure behind them. Only works for the bucket lift though. If it goes into float super easy, good chance spool groves are getting worn. Like said though it does take practice and getting a feel for the way the hydraulics work.
  • Similar Content
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
    • bo dawg
      By bo dawg
      Is it hard to pull apart to replace seals? Any tricks? Or things to watch for?
