rmaynard
416-H/ARK Loader Fitment Issue
rmaynard
The pump is directional.
From the top
wallfish
Although it's difficult without physically seeing, touching and measuring, I'm still of the opinion the pump could go up in front of the PTO like the location of the red pump in my pic.
Remove the brace for now and then address that problem after the pump is mounted.
WNYPCRepair
Or is there any way to attach a mount to the diagonal brace and mount the pump to that?
rmaynard
The problem is that the pump is directional and the body of the pump conflicts with the brace when the pulley is aligned with the PTO. Move it under the brace and the tire hits it when turning right. Move it above the brace and the pulley hits the muffler. Move it forward and it hits the vertical portion of the hood.
See my reply to wallfish above.
WNYPCRepair
Is there anywhere in this area the pump could be mounted, if someone could fabricate a mount?
elcamino/wheelhorse
If you remove the muffler and replace with a stack ,would that help ?
WNYPCRepair
I missed this picture before. This is what I meant. Could you physically fit it in this general area, lower or more forward, etc., if you could fabricate a mount?
wallfish
Or a new bi-directional pump is about $200
http://www.northerntool.com/shop/tools/product_200329712_200329712
Tire will hit that area in the circle
WNYPCRepair
Could you bold a flat plate on top of the front mount, then mount the pump there, or will the loader's front cross brace hit it?
rmaynard
Thanks for all the suggestions. Here are a few more answers:
@elcamino/wheelhorse Don't like stacks. Fabricating a header would be more involved than fabricating some sort of bracket for the pump.
@WNYPCRepair Mounting on front plate would conflict with diagonal brace.and hood.
@wallfish A new bi-directional pump and hoses is way over my budget, which has been blown to pieces already with upgrading the front axle to hubs and 6 plies.
@wallfish @WNYPCRepair If I could get a detailed picture of how John made the bracket to mount the pump below the PTO, that might be the answer.
WNYPCRepair
Your tachomatic isn't being used, you could fabricate something using that
rmaynard
Tach-A-Matic? Maybe.
@wallfish Does it matter which pulley of the PTO (inner or outer) that the belt goes on?
MalMac
I know this does not answer your question, but the Ark 550 goes on the outer.
rmaynard
Thanks.
WHX??
I don't think it would matter,  inner would be best (bigger diameter) perhaps giving you more flow  through the pump and faster cycle times?
roadapples
Mine is on the outer pulley, and I`m sure it`s factory..
WNYPCRepair
It would only matter as far as the max RPMs of the pump
wallfish
I can get you some pics. But I think your pedal has a bit more travel than my brake does. The bracket is basically made with 2 pieces of angle together but a straight piece of flat bar will work. I just used what I had at the time. It's spaced off the frame using a spacer and a long 3/8 bolt. The adjustment piece connects to the bottom piece and the sub-frame and stabilizes it. Custom guard was added just in case the belt breaks or something. All that plumbing was done so the tire doesn't hit anything and the other side because the hose was short.
Is there some reason you're against modifying the brace? Just seem to be glossing over it since it was mentioned twice. It's only common angle steel. Make a new piece and save the original piece if that's a concern.
I have used my loader with the brace completely disconnected because a bolt holding the front came loose and didn't notice it until after using it. Plus mine is only thin wall tube.
Don't think it's going to make any difference but it will change the RPMs a bit.
My factory pump is lined up with the inner pulley with all the factory brackets.
wallfish
Here's a quick drawing, No welding necessary.
The brace should probably be slotted to adjust belt tension.
main pump plate 3/16 or 1/4" flat bar. Might not have to be as wide if you drill pump mount holes vertical instead of horizontal
Edited by wallfish
rmaynard
Thanks for the drawings and info. I am going to take another look this evening now that the rain has moved out.
The reason that I have not addressed the angle brace is simply because I don't like modifying anything that is a structural component.
WHX??
Don't worry Bob...sounds like 'fish knows a thing or two about structural
Or does he??:ychain:
'Sides when you are challenged in the art of joining metals via electricity a project such as this  can be difficult...ask me how I know!
wallfish
Ha, I know nothing!!!!!!!!!!!!!! but certain things I'm comfortable with. If it was 6000 lbs with someone working underneath it, get an engineer! But carrying 300 lbs at 7 mph, Duct tape and vice grips will hold that. LoL
Don't worry too much about that brace, not that much structure to it unless you're carrying 600 lbs and bouncing full speed through some ruts for a 100 yards.
It definitely has a purpose but it's made the easiest way, located in the easiest spot for manufacturing and it looks good there. Moving it a little will not compromise it's purpose IMO.
  • Like 4
DennisThornton
If I was near by I'd be tempted to agree and conclude that indeed there is certainly no way it could possibly work and then make you an offer!  B)  But I'm not so I'm not, BUT!
Crap!  There's always a way!  AND, you have the best of the best here to help you (self NOT included!).  Hang in there a bit and see what the other Pros have to say!
wallfish
MISTAKE ---  My factory pump is on the outer pulley too. Backhoe pump on the inner pulley.
Still don't think it matters much especially if you need the room.
rmaynard
Well yesterday provided much stress, cussing, and throwing of things. Then today, after a morning of yard sales, I went to TSC and purchased two different size belts. Already having a 26", a 28" and a 31" belt on hand was not enough. I ended up with a new 29" and 30". I modified my bracket some more, changed it's location, and with a 30" belt I seemed to hit the sweet spot. Pump pulley lines up with the inner PTO pulley. Pump sits low enough that there is no conflict with the brace. The belt no longer rubs on the PTO hoop, and when I turn the wheel all the way to the right, there is no longer any conflict with the plumbing. Since this 416-H is getting a swept-forward axle and trailer hubs, that should even further move the tire away from the pump and hoses. So here are today's pictures:
From the side..
Clearing the brace..
Looking down onto the tire showing how it clears the lower hose..
View from the front..
Now I need to get some longer hoses, and I need to make a brace to secure the top flange of the pump.
Edited by rmaynard
  • Like 6
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • edwroy
      By edwroy
      Needs some help. Purchased an ARK Loader - Model 550 Serial # 573 - anyone know what year this might be?
      Thanks,
      Edwroy
    • boovuc
      By boovuc
      Well the Grange Fair was a short visit!
      Started uninterrupted work on the loader at about 1:30 this afternoon. Finished at 8:20! It was worth it. After some cutting, grinding, filing and minimal cursing because I had no time constraints, I got it on. Thanks to my Karen who slid the tractor under the mount while I held the frame up. (Never made the stands. Used the brace arms to get it off the blocks). No leaks, no seeps, no noises, and full function of everything. Pump is very quiet and barely moves the vacuum gauge on the tractor. Much less work for the motor than my 48 inch mower deck.
      I didn't put the rear weight on so I took it easy and made sure everything was primed in the lines. Plenty of down pressure and fast movement. A big thank you to Malmac, Scott, Wallfish and the others who offered advice and posted pics of their loaders. The biggest pains in putting this on a 520 since it wasn't factory designed for any of the Onan powered tractors was the pump mount and the lever release/lock Attach a matic that is used on the newer tractors and the 1991 520-H. (My 1992 416-8 didn't have the lever design).
      It required cutting out a long skinny triangle from the thick metal original sub frame to allow alignment of the frame holes and shortening the actual lever. (The frame cut took three cutting disks and a good portion of a fourth). I also had some issues with the nut/bolt used on the front mounting bracket. The first frame hole on each side has VERY little room to start a nut. (Because of the gear reduction steering assembly). On the positive end, the factory brace arms leave plenty of clearance around the Onan and hood. My suction line to the pump will need moved since it is in harms way. I think the pump is OK where it is at with a guard to be made soon. I'll work it harder on Monday and really heat the oil up and check again for leaks or seeps again. I do have to weld a wallowed loader lift cylinder pin hole but even it isn't too bad. The others are real tight. Not bad for as old as it is and for 500 bucks.
      This was always a real want for me so please excuse my over exuberance. This makes the beginning of the work week a joy! It might take until noon at work tomorrow to wipe this grin off my face!
    • chevyaddict83
      By chevyaddict83
      So, i ended up rebuilding curl pistons, worked great. Now, having lift issues. If i pull on the lift lever slightly, i still get the arms to go up. If i pull all the way back, the whole thing drops. If i leave it raised and fill the bucket, it stays up and dumps fine. Is it something in the control valve? Maybe an adjustment?
      Sent from my LG-LS980 using Tapatalk
    • prondzy
      By prondzy
      So i have an ark 508 loader on my c160. I was wondering if any of the other Ark FEL owners could tell me if there is a "float" postion in the spool valve?
