doc724
Eaton 1100 brake shaft seal part number
doc724
Can someone confirm what is the Toro (or SKF) part number for the brake shaft seal on an Eaton 1100?  It does not appear to be the same part number (SKF 7410) as the eight speeds.  The Eaton looks to be a larger diameter, but I don't want to go messing around to pull the out the bad one to find out without knowing the part number.  I studied the IPL's for the Toro part for a C125 with Eaton 1100 and a 416H and I could not find the seal pictured anywhere.  I found the brake shaft, but not the seal.  Thx
doc724
It could be...that was my guess.  Picture is not the best.  I need to measure the OD on the machine.  2.25 nominal OD seems too big.  a typo?  1.25 seems more reasonable
Is there a cross reference table for Toro to CR and SKF somewhere on the internet?
gwest_ca
Right you are. 1.254" OD
http://www2.chicago-rawhide.com/popup_parts_lookup_457012.htm
When a seal number comes up that is colored click on that to get to the dimensions.
Garry
doc724
Wow, things are getting freaky on the internet.  I was on the CR Product data page for 7443 and I get this pop-up that you quoted me on a RS reply.  Never had anything like that before.  This is a new upgrade to Firefox that I am running so maybe that is why.  Sheesh, talking about big brother watching.  George Orwell was right, he just got his dates wrong!
