Vrocko
B-80 spindle bearings
Vrocko
I have a 75 B-80.Trying to replace the bearings in the main drive pulley.What direction do i drive the shaft out of the spindle.
daveoman1966
What mower deck are you working with?   36"  42"  Are they cast iron spindles, or made of alum / pot metal?
KC9KAS
Vrocko
Sorry Daveoman1966 the site would not let me respond. It's a 36 deck. It's cast iron. I got the sleeve out of the spindle. How do I go about removing the bearings.Heres a pic.
gwest_ca
That looks like the 103119 bearing that Toro no longer carries. Still available from others including Napa
https://www.rcpw.com/search/?quest=103119
It comes with the shaft.
Check a parts list if you know the model number of your deck.
Garry
daveoman1966
EBAY HAS THEM TOO..    JUST SEARCH ON BEARING 103119.   AROUND $40 BUX EACH...;SET OF 3 FOR $80 OR SO.
THERE IS A RIGHT AND WRONG WAY TO PRESS THE BEARING BACK INTO THE HOUSING....NOTE THE LOCATION OF THE "RING-AROUND-THE BEARING".
iT MUST BE ON THE TOP SIDE OF THE HOUSING
Vrocko
Thanks for the help. I'm well on my way to resurrecting this family heirloom.
