Sherard
What model and year is it?
Sherard
  • Like 8
rj35hunter
Looks like a 1960 550....
Sherard
1st vintage tractor purchase. Love it but no idea of year or model.
Sherard
Found 1960 550 on line and sure looks like it.  Thanks
roadapples
:WRS:
KC9KAS
@Sherard Nice tractor and :WRS:
AMC RULES
:WRS:
SylvanLakeWH
:text-welcomeconfetti:
953 nut
:text-coolphotos:                The Suburbans are a lot of fun to drive, Just watch out for wheelies! They are mighty light in the front.
:text-welcomeconfetti:    to  :rs:
Retired Wrencher
      Sherard           :WRS:  Looks like a nice tractor.  Enjoy it.
T-Mo
:WRS:
Nice first purchase of a vintage machine.  Nice score.
ACman
:text-google: nice Sububan! and welcome to RED SQUARE .
Sherard
Thanks everybody.  It puts a smile on my husband's face. Runs like a champ and looks fairly original. It came with attachments like discs, plow, something like a rake but different name. Told you we don't know much about it. : )   how do we find out more about it and ballpark value?  Planning on some local  event with vintage tractors to talk with folks. Any other suggestions?
  • Similar Content
    • Jennifer
      By Jennifer
      Okay friends husband and I brought home another mutilated mutation that I felt sorry for and wanted to fix….  Questions will it run??  Lol… what model for sure?  So I believe it’s an 854 and would like feed back to confirm..  lots of stuff coming off… has the k181s tag on the engine!  Two piece gas tank!  So if my friends on here would agree or disagree I would be able to see how much I have been learning over the years!
    • 1st horse
      By 1st horse
      Trying to figure out exactly what I have a friend gave it to me said it was a 1963 8hp Kohler he's right on the engine but I think he is off on the year and I can't find a serial or model number on it I got intending to completely restore it but I really need to identify what I have I would really appreciate any help and advice
    • JP56
      By JP56
      I purchased what I was told by the seller, to be a "partially restored" 1975 C Series. I have it now for 3 seasons & have concluded that this restoration consisted of replacing a few bolts and repainting it and replacing some of the decals. The seller told me he "screwed up" on the Model Decals when he ordered them, & put the wrong one on it (C120), but did not tell me the correct one that should be on it, and he gave me a 1975 C Series Owners Manual with it. I am wondering if the Model Numbers correlate to the horsepower of the engines. If that is the case, I must have a C100, because mine has the Kohler 10 HP engine, which is labeled as a K241S. It has an 8 Speed Manual Transmission.
      After getting it home and using it, I put it in my shed & the next time I went to use it, I see the transmission/gearbox has leaked oil onto the shed floor, appears to be coming from the seam between the two halves of the rear-end. I also see a heavy black greasy film build up at both axle seals & also around the brake drum seal. I am now in doubt of the recommended oil for the rear end. Some of the online forums say that they had begun using transmission fluid as a replacement for older types of lubes, while others say 10-30 motor oil. I saw someplace which I can't seem to find again right now, that 85W-140 gear lube was what should be used. The oil level on the dipstick has not dropped to low levels, and appears to be motor oil, so after searching around and also checking the manual given to me with the tractor, I top off the level with 10W-30 as spec'd on page 5 of the manual(if this is indeed the right manual for my year and model).
      My problem now, is that last season, it suddenly seemed to get a bit sluggish & slow down as it gets warmer during use. I believe my sluggishness problem might be due to the leak in the box seam and possibly also the type of fluid/lube in the case of the transmission/gearbox. I had already tweaked the carb as best I could, changed the fuel filter, replaced the spark plug due to a hard starting condition and rough running, & it seems to be running fine right now except for a backfire when shutting it down. I have purchased a replacement carb for it that I have to put on now, & I am pretty sure I need to locate & change the points as well.
      Anyway I am hoping that someone can point me towards the right manuals, by placing all numbers I have been able to find on it here so I can hopefully find the right service/repair manuals (hopefully as free downloads someplace online) for the different systems.
      Tractor:
      Model: 103909
      Serial Number: 47404
      Engine:
      Model: K241S
      Specs: 46636D
      S/N: 6097616
      Deck: 0542M505
      All Numbers on Transmission/Gearbox Casting:
      A24
      8163 or B163 ?(Cannot Read Clearly)
      101761 or 1017G1 ?(Cannot Read Clearly)
      Any and all advice/info anyone can supply me with on this would be greatly appreciated! Also, any tips on good places to purchase reasonably priced parts would be good as well.
    • Team70R
      By Team70R
      Just scored what I believe to be a c120. But I'm not sure. It has the 3 speed unidrive, which I know is incorrect. Not sure if it's been swapped or if something else is out of place. It looks the serial number plate was stamped twice!?
    • Don_G
      By Don_G
      I picked up a Toro, Wheel Horse 522xi but it doesn't have a model or serial number ID tag on it anywhere?  Is there any feature or something to determine the year and other ID?  I have the engine data: Kohler mod CH22S, Spec 66545, disp 624, serial number 2813615731.  It has tilt steering, high/low hydrostatic drive and a 60" deck but the deck ID tag is missing the 2/3's of it that had it's model and serial number.  Pictures attached:
      Additional pictures:
