Aaron's Wheelhorse 0 #1 Posted August 8, 2016 I just recently got this Whellhorse 211-5 and it not mowing the grass that well. I jacked it up yesterday and a whole blade and washer and nut is missing. it has 3 mower blade heads I cant find a part number at all the only number i can visabilly see is the part number on the mower deck wheel horse 0542SB02 46003 The two blades thet i took off are so worn out and the mesurement i get out of them is 13 1\2 inches . I found some online for $9.99 a peice they are 13 and 7\8 inches Would these work on this mower? Thanks in Adavance Regards, Aaron Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,032 #2 Posted August 8, 2016 Original blades 106077 replaced by Toro 3-blade set 106636 (3/4" round hole) Napa 3 of 7-04533 Garry Share this post Link to post Share on other sites
KC9KAS 4,741 #3 Posted August 9, 2016 @Aaron's Wheelhorse I thought at 1 time I was told that mower blades were measured "diagonally" from the sharp corner on 1 end to the sharp corner on the other side. Share this post Link to post Share on other sites
