wwww12345
Is a wheel horse 520h a decent tractor for pulling?
wwww12345
Hello everyone, I am looking at a wheel horse to convert to a pulling tractor. I have the opportunity to purchase a 1988 520h. Would this be a good tractor to pull and is this a good tractor overall?
Thanks!
slammer302
I don't think it would be the best candidate for a competitive pulling tractor. If it is just for fun and you are basically just going to keep it stock and add sum tires and stack sum weight on it then have fun. most pullers seem to stick with standard transmissions and the 520H is a hydro.
Achto
:text-yeahthat: Hydro's do not make good pullers!
  • Similar Content
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • Poppa Phill
      By Poppa Phill
      Ive Got an 88 520 and a 60 inch deck.
      My 522 gave up the ghost and being up here in maine I refused to buy a JD .
      Needing the deck mule with the spring,
      also looking for a soft cab.
      Thanks
    • Joe Reese
      By Joe Reese
      Wheelhorse Snow blower Fits c100's 500's etc. with a front mule setup. Works. Comes with lift Flag & Lift spring relief. Also have a set of rear tire chains for additional - $50
      Have a set of custom exctra heavy rear wheel weights if interested as well. $75
      Snow Blower Only, Tractor Not For Sale.
    • Joe Reese
      By Joe Reese
      60 Inch wheel horse mower deck with no rot. All spindles greased and spin smoothly. Comes with mule pulley guard & deck belt covers and the rare offset front mule. Has standard blades installed. Have brand new gator mulching blades for an additional $50 Great       Joe Reese
