953 nut
:text-coolphotos:                 I like the flipped frame lowering job, by the Big Show 2017 you should have that lead sled ready to go Krusin!
ACman
  :text-yeahthat:, Build it Ed !
squonk
That hood looks kinda cool that way. If only you could find some tiny teardrop lights for the corners.
Ed Kennell
I may have to watch my diet this winter so I can squeeze my rear into the bucket next summer.
That hood was off a raider that did a back flip off a trailer resulting in a mashed steering wheel and a  hood and grill was folded together.  This was one hood I didn't hesitate to cut up.
BTW, The flipped  Raider with new hood and wheel is alive and well.
  • Like 5
DougC
Put some drag slicks on and add a canopy over that sunken bucket seat  and get ready to do a burn out with that :wh: custom top fuel dragster!!!   And
        :wwp:
Edited by DougC
  • Like 5
AMC RULES
Shouldn't the rollcage dictate...
using the 22hp twin.   :dunno:
  • Like 6
bmsgaffer
:text-yeahthat:
:auto-layrubber:
DennisThornton
Well, looks like I'm going to have to "Follow" this!
953 nut
:text-coolphotos:   Padded arm rests!   :woohoo:
  • Like 4
ACman
I likey!!! :confusion-helpsos: ... I just fell out chair , that thing is going to be :wicked: and your wondering what engine you should use !
  • Like 4
DougC
What size chute are you going to deploy at the finish line to slow down that HF Predator beast?    :auto-checkeredflag:
19richie66
Looks cool!
Ed Kennell
PARACHUTE FOR DRAG RACE DOOR CAR COMBO KIT        This should stop CRAZY HORSE.
  • Like 4
Ed Kennell
Got all the major parts pretty much in position.    Got the front axle and steering figured out.  Still need to get an engine and build a clutch.
  • Like 9
19richie66
That looks very cool Ed! I like the way you chopped the grille.
953 nut
:text-coolphotos:  Ed, it is a good thing you are so slim, several of us couldn't get out of that seat,  :ychain:    I like the hood scoop, the ram air effect should be good for high speed crusin.    :handgestures-thumbupright:
elcamino/wheelhorse
Ed , what size engine are you going to stuff in there? Have you made provisions for a 4 pt seat belt ? :auto-swerve:
953 nut
Don't forget to make provisions for a chute!
winternationals-drag-race-the-dean-moon-mooneyes-dragster-pops-the-picture-id163090541
Ed Kennell
That hood was on a wrecked Raider Richie.  The hood and grill were folded together at the headlight opening  when I bought it, so It was a good candidate for a chop job.  I just cut out the wrinkled area and welded it back together.
If I don't lay off the pies, I may not fit either.  Pretty easy to cut the back panel and move the fenders out for wider bottoms....if necessary.
Not sure the ram will give me anymore HP, but if I go with a big K series, the scoop will cover the spark plug that will be sticking thru the hood.
Haven't decided yet Jim.   Kinda waiting for something with some HP to show up.        Yeah, I have some ideas for the 4 point and a seat ejector.
Got it Dick....check post #16.
oliver2-44
Cool build!
how about a rocket engine nozzle on the rear,,,,,,,or go the olher way and put a bib wind up key on it!
Ed Kennell
Hard to believe It's been 2 months since I worked on this project.
I got the boat winterized and put away for the winter this morning so the low rider project got some attention this afternoon.
I had bought a non runner C-105 a few weeks  ago  just for the 8 speed for the  LRer.
It actually had a K321AS transplanted that the PO said hadn't run for years.
After chasing grounds or lack of grounds for quite a while, I finally got fire and got it running by hand feeding fuel in the carb.
This is what I found in the totally plugged tank shut off valve.
It has a Walbro carb, so I didn't even check it out...just bought a new one from the jungle for $35.
I hooked up a high temporary tank and It starts and runs perfect with no smoke,  so the 321 is going in the LRer
So this afternoon, the transplant began...
The first job ...not my favorite...was to remove the hitch from the 8 speed.IMG_6492.JPG
 Then remove the 8 speed.
Fit up the seat pan and fenders.
Then Pulled the engine out of the C-105.
Man I hope I can stuff that under the hood!
That's all for today folks....Mrs K is calling me for dinner.
  • Like 8
953 nut
:text-coolphotos:                       The shift levers will be a bit cozy!    :scared-eek:                Don't stop too fast.      :ychain:
