beekay42 4 #1 Posted July 30, 2016 I have a 1976 wheel horse c-160 tractor. 1st question. I am looking for a trailer receiver hitch mount that connects to the tractor rear end.The oem one is not heavy enough. I want to tow my utility trailer that has a 2 inch ball. I had talked to someone on this site that made these few years ago. Does any make these any more? I would like to purchase one. I'm also having trouble with my left front wheel snap ring popping off when I move the tractor, any remedies for this? Has anyone had this same issue? I thought about drilling it out and tapping it. Need suggestion please! Share this post Link to post Share on other sites
953 nut 56,155 #2 Posted July 30, 2016 Here is a vendor for the hitch you want. As for the snap ring, Have you replaced it with a new one? Also, if you jack it up how much plat do you have on the left sode compared to the right? http://www.wheelhorseforum.com/forum/141-wheelhorseman1000s-hitches-brackets-parts-and-more/ 2 Share this post Link to post Share on other sites
DougC 2,641 #3 Posted July 30, 2016 Hello beekay42 and Enjoy the forum. Share this post Link to post Share on other sites
benji756 341 #4 Posted July 30, 2016 the ring groove for your snapring may be worn enough that it won't stay Share this post Link to post Share on other sites
beekay42 4 #5 Posted July 30, 2016 2 hours ago, 953 nut said: Here is a vendor for the hitch you want. As for the snap ring, Have you replaced it with a new one? Also, if you jack it up how much plat do you have on the left sode compared to the right? http://www.wheelhorseforum.com/forum/141-wheelhorseman1000s-hitches-brackets-parts-and-more/ I appreciate the info. I have not replaced the snap ring. I do have more play in the left side. How much should there be? Share this post Link to post Share on other sites
953 nut 56,155 #6 Posted July 31, 2016 Check this out. 1 Share this post Link to post Share on other sites
clueless 3,012 #8 Posted July 31, 2016 13 minutes ago, AMC RULES said: Ordered one from Tom two days ago, he said he was going to fab a few up in the next couple of weeks. Good guy, and a great price. 1 Share this post Link to post Share on other sites
857 horse 2,581 #10 Posted July 31, 2016 Built like a safe,,,,,,,One good investment.....the tractor will break before the hitch goes anywhere....... This should have been a factory option or accessory.. Tom is a very nice guy................I have 2 of these ......worth GOLD !!!!! 4 Share this post Link to post Share on other sites
roadapples 6,983 #11 Posted July 31, 2016 That is one nice looking rear.....I know I`m old.. 1 Share this post Link to post Share on other sites
stevasaurus 22,910 #12 Posted July 31, 2016 I think the snap rings have a flat side and the other side is beveled a little. If so, the flat side should be out. Replace the snap ring, and you might be able to clean up the groove with a hack saw...doesn't take much. Drilling and tapping would be a last resort, but that does work...just ask my 702. 2 Share this post Link to post Share on other sites
oldredrider 2,553 #13 Posted July 31, 2016 The snap ring set up on the spindle was an under engineered boo boo. Too much is demanded of the spindles on a garden tractor for snap rings. I have worked around the problem by drilling the spindles for cotter keys. Leave clearance for a washer and you're good to go. 3 Share this post Link to post Share on other sites
beekay42 4 #14 Posted August 2, 2016 On 7/30/2016 at 5:36 PM, 953 nut said: Here is a vendor for the hitch you want. As for the snap ring, Have you replaced it with a new one? Also, if you jack it up how much plat do you have on the left sode compared to the right? http://www.wheelhorseforum.com/forum/141-wheelhorseman1000s-hitches-brackets-parts-and-more/ I appreciate the info. I have not replaced the snap ring. I do have more play in the left side. How much should there be? Thanks for all the info. I really appreciate all the responses. This forum is great place to find very knowledgeable people who like to share their experiences. 2 Share this post Link to post Share on other sites
oldredrider 2,553 #15 Posted August 2, 2016 If I remember correctly, there should be .015 clearance between the bearing and outside washer. 2 Share this post Link to post Share on other sites
Marv 949 #16 Posted August 2, 2016 Yes .015 is correct. Marvin 1 Share this post Link to post Share on other sites
