mtnpilot99
Onan Engine Identification Help
mtnpilot99
Hello, I'm new to the site and I'm hoping I can find some help with identifying a crossover engine or parts for the Onan Generator I'm having an ignition problem with. If this thread is too unrelated specifically to tractors, please delete thread - I'll understand. If ok with the thread, the problem I'm having is that I have a 1989 Onan 9KW MME (2 Cyl.) marine generator that has a faulty electronic module (igniter) that needs to be replaced. Normally this is as simple as going to one of the Onan parts sites and purchasing for 80 or 90 bucks - as most of them are priced. But for whatever reason, Onan (Cummins) has chosen to price this particular electronic module at over $1,500. Some of the sites I visited have listed this part at over $2,000. My question and the help I'm looking for is whether anyone has any knowledge of a crossover electronic module (or the whole distributor assembly) that can be used with this Onan engine? I'm hoping Onan used a similarly enough 2 cyl. engine in their tractor line where the same (or similar enough) module could be used and is considerably cheaper. Onan references the the electronic module as part# 186-3203 and sometimes calls it an igniter.
Thanks again for any help!  -Mike
boomers_influence
mike
my 2016 L-835 says 1117.16. ( onan price sheet )
BUT over the counter adds 20%
that brings it to 1340.58.
in my parts manual it looks like an electronic module inside the distributor
to replace the points.
the L-835 calls it points, the parts manual calls it an igniter.
i have no good answer for you.
BUT, i would bring it up at smokstak.com
they may be able to help.
thank you. boomer ( the used onan engine parts guy, also NOS and new )
benji756
:banana-rock::text-welcomeconfetti:
KC9KAS
@mtnpilot99 :WRS:
I know Onan parts are high!
My brother has a P216 and a rebuild kit is over $1000...an that is standard size!
woodchuckfarmer
Hunt for after market parts there out there.
mtnpilot99
Thanks everyone for the replies. I'll keep hunting....
onanparts.com
Give these guys a call, www.srsales.com
They have a couple of the 186-3203 modules for $495.00, Sure beats double or triple that.
Good luck!
mtnpilot99
Thanks onanparts.com, I'll give them a try!
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
    • DVail2000
      By DVail2000
      Ok, So I am seeing that most of you are leaning towards the ONAN engines being crap.  That said, I have 2 416's  # 1 is a -8 and # 2 is a -H.  Both have the -216 in them.  i was thinking of rebuilding the engine from the 416-H, but I am also considering changing the engine out with a different type.  What are the recomendations? I am seeing Koler, what else will fit?
      Thanks
      Dave.
