Bigfish 146 #1 Posted July 13, 2016 (edited) Something ive been wanting to explore is, making my wheel horse kohlers quieter. My family and I frequently camp and hang out at the local camp ground a few county roads over. We always take a horse or two with carts to ride around with but anything above idle is too loud for most folks and disturbs the quiet. What are some recomendations for lowering the db level and making it golfcart quiet or better? Edited July 13, 2016 by Bigfish Share this post Link to post Share on other sites
953 nut 63,023 #2 Posted July 13, 2016 Many moons ago I did a lot of welding with a Kohler powered Lincoln welder mounted on the back of a Cushman three wheeler. I bought an automotive muffler and the fittings to hook it up, so quiet I could carry on a conversation right next to it. 2 Share this post Link to post Share on other sites
Bigfish 146 #3 Posted July 13, 2016 29 minutes ago, 953 nut said: Many moons ago I did a lot of welding with a Kohler powered Lincoln welder mounted on the back of a Cushman three wheeler. I bought an automotive muffler and the fittings to hook it up, so quiet I could carry on a conversation right next to it. So a small auto muffler is the trick? Damn i feel stupid. Did you rout it out the back or under away from you? 1 Share this post Link to post Share on other sites
953 nut 63,023 #4 Posted July 13, 2016 I don't remember what the muffler was from, but it was not small, used a belled pipe fitting to go from 1" up to 2" then a 90 with a nipple and the muffler went up on top with a brace coming down. Of course this was on the back of a three wheel industrial cart, for your application you would want a smaller one; could be straight up or may be able to fabricate a bracket that will go into the mid mount tach-a matic and a tail pipe out the back. Share this post Link to post Share on other sites
Bigfish 146 #5 Posted July 13, 2016 Humm. The 312's we take have alot of clearance under. I wonder if we could go down under, go in by the break and come out he by the clutch pedal with a muffler below? A muffler cant be the only solution Share this post Link to post Share on other sites
pacer 3,177 #6 Posted July 13, 2016 A long pipe in itself will reduce noise, so running it underneath is the first thing I'd do. Next, I think I'd look into RV power plant mufflers, they're always quiet --- and, usually have a long pipe. Share this post Link to post Share on other sites
N3PUY 1,031 #7 Posted July 14, 2016 The exhaust noise is the hot exhaust air reacting with the cool outside air. An exhaust system is actually cooling the air. The air coming out of the tailpipe is much colder than the air in the exhaust manifold. A muffler increases the length of the exhaust system. A straight thru muffler is a loud exhaust system. Share this post Link to post Share on other sites
Don1977 605 #8 Posted July 14, 2016 Here is what I did on my 18 Hp Vanguard. It's not as quite as you want. It was a straight pipe before the washers were added. This killed the high pitch noise and made it acceptable. The first washer has 1" hole and the outer ones are 3/4" they are seperated with 1/4" nuts that I drilled the treads out. This should quiteing a muffler as mine has nothing else in it. 2 Share this post Link to post Share on other sites
