moe1965 746 #1 Posted July 10, 2016 I have a raider 10 I'm not sure on the correct oil level for the trans. I filled it until it came out of the check plug on the side but it shows no sign on the dip stick. Is that just a drain plug and not a level indicator? Any help would be apreciated. Thanks in advance. Jk Share this post Link to post Share on other sites
rmaynard 15,633 #2 Posted July 10, 2016 (edited) You cannot use the plug on the side for filling or checking. If you do, you will be about 8 to 10oz. low. If you have a dip stick, fill with gear oil until the level is correct on the stick. Otherwise, the proper amount to add to a totally empty transmission is 2 qts.. I fill through the shifter hole with the shifter removed. You can fill through the dip stick tube if the oil is warm and you have all day. Edited July 10, 2016 by rmaynard Share this post Link to post Share on other sites
moe1965 746 #3 Posted July 10, 2016 Thanks. I'll fill through dipstick tube. I'm in the middle of painting a snow blower attachment and have time between coats of paint. kinda strange working on a snow blower when it's 85 out. Share this post Link to post Share on other sites
