Similar Content
By Team70R
Its absolutely freezing here in Indiana and I've been plowing some snow with the C165. I've noticed some grinding when driving it and when I shut it off in neutral and go to push it it grinds even worse and the tires are fighting each other. The input shaft doesn't turn when I push or pull the tractor in "neutral" which is good.. Is it possible the shifter screw is loose?
By Zeke98
Hi All,
I'm almost ready to purchase a Cyclone Rake. I purchased and installed a great hitch from Tom (a vendor on the site) to better handle the Cyclone Rake.
As I'm looking at models of the Cyclone Rakes and the fact that they don't jackknife, I'm wondering how sharply the tractor will turn with the CR attached. I have some tight turns to make. I recognize that the wheels on the CR swivel, but could someone give a rough idea of the turning radius with the CR attached? Perhaps compare it to turning with a standard utility trailer that swivels at the hitch connection? Obviously, I'll be opting for a smaller CR for better maneuverability.
Here's a photo of the custom hitch by Tom (I added the receiver and painted it).
Thanks for any help.
By cschannuth
Hello all. I'm new to the forum and have my Dad's 1978 C-161. How can I increase ground speed? I don't want to race the neighbors or anything but I cruise the property with it. I don't mow with it but use it to move trailers, pull a lawn roller, pull spreaders, etc. It's in really great condition and everything works but ground speed is pretty slow. Plus, as you know, Low range is really slow. Thanks for any help and I hope I put this in the correct section of the forum.
By johnidi
Hoping someone can help answer this question. I Have a 523Dxi and I'mm looking for a plow/blade. I found this item for sale and told it came off a wheel horse commando 800 large frame. Would this fit my Wheel horse? Or do you have another suggestion.
Thanks
By milspec762
I just picked this up. Its a 1998 522Xi with kwik-way Front End Loader. for $2800 the hour meter is showing 327 hours. The guy claimed to be the original owner.
Im new to the wheel horse's but very much becoming a fan. In my eyes Its a great little tractor. I just was curious if was good buy as I couldn't find anything to compare it to for sale.
