![Kegler](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By bigbuck
I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
please call George at 517-499-5678 for more info.
By SethL1984
312-8 - Runs, new carb, ignition doesn't work. Was bought for parts, ended up being mower. Rear Attach-a-matic bracket
417-8 - Runs well, electric lift, ignition may need cleaned (or started solenoid going). Rear Attach-a-matic bracket
(1) 42" RD with mule drive. Cuts well!
(1) 48" SD with mule drive.
(1) 37" SD.
(1) 48" snow plow. 5 way blade position I believe.
Several other parts/WH odds/ends. One tractor does include the weights and chains.
Parents are moving and, unfortunately, need to thin the herd!
By cJ_3D
Hey all!
Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
CJ
By bkarp@roadrunner.com
my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
By Tinman1962
Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
