clueless 3,012 #1 Posted June 24, 2016 Got a 1977 b-80 with a 8 speed, Best place to fill it, dip stick, shifter hole, or small filler hole on bottom left side? also how much? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,107 #2 Posted June 24, 2016 I like using the shifter hole. Two quarts goes in quick. If you lift the front of the tractor up when draining you get more out as some is trapped behind a ridge in the center of the case for the through bolt. Garry Share this post Link to post Share on other sites
skrusins 128 #3 Posted June 24, 2016 (edited) Can the rollpin that connects the linkage to the trans be sheared? Edited June 24, 2016 by skrusins Wrong one opinion for the 308-8 Share this post Link to post Share on other sites
