Charger 12 attachments on 3 series tractor?
By
bizzo15, in Wheel Horse Tractors
Similar Content
By D_Mac
Well...... what's too many horses ? Is to many when you have no more room in the garage so you have to start leaving them outside ? You can say you are "tractor heavy " but are you really ? Right @WHX??. I picked this up today. I'm not really a parts buying guy, unless I need them, but I saw this listed and you know. Love at first sight. Appears i just bought a 1969 Charger 10. Or parts of one. PO removed the original tecumseh engine and was going to install this 10hp Kohler. Well as you can see he didnt get far. Engine is on frame not properly secured and nothing else is hooked up. Nothing. Wires hanging all over. Parts off of it. Im not sure if i have everything. I also am unfamiliar with these " newer engines" that dont have the old starter generator. Not sure what works and what dosnt. Just got it home. If you kind fellas can take a look at what i photographed and tell me whats missing or what i will need to attempt to get this thing running again or if I just should rob some parts from it. Wiring it will be very difficult for me. I have said 100Xs I'm a horrible mechanic and even worse electrician. What ever I decide to do with it your opinions will be appreciated. Thanks
By blu_stang
Hi All, It's time for me to sell the D-250 I've had for the last 8 years. It’s useable as is, or would be a great project bundle for further restoration.
I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains. Also included is an extensive part collection, nearly a second tractor worth. I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine. I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts. There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
The tractor engine runs smooth. There are around 1050 original hours on it; It’s a 1976 edition. Everything works, except the dash lights and the rear lights (disconnected b/c of fender). I just haven't sorted out the wiring, but it is all there. Headlights are good and working, as are all of the gears and levers. The four tires are nearly new Carlisle Multi Trac, with nubs still on them. The rear tires have been filled (ballasted) with Rim Guard for extra traction. The hydraulic pump, front PTO clutch and brakes operate but could use a tune up. I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat. The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings. The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows. The rear fender needs a repair, but all pieces are available. The plow and tiller are due for restoration. The Points, Condenser and rotor have all been replaced and tuned in. The battery is good. I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours. The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
Here's a video of me mowing, this past summer.
Transporting this haul in one trip will require a pickup truck and a large trailer.
By Jayzauto
GMorning Gang,
Last year I had purchased an old C175 with blown engine and all the attachments the owner had with it, including the FEL. He gave me everything he had, or thought he had. It was quite a pile, requiring 2 trips. Of course, in the heat of the moment, it appeared everything was there, except belts for the most part. He even had most of the original documentation. Now I know what your thinking, and you'd be correct...... everything was Not there. And as we all know, it's the little things that hold up the project AND seem to cost the most money.... mot to mention the heartache. But, I did find an engine, got the tiller installed and working, the plow mounted, the deck running. Now for the Big hit..... The FEL. I do seem to have most of it.... The bucket and arms assembly, lower frame, weight box. weights, chains and even the pump , with brackets that was still mounted to the blown engine. The show stopper here is what is called the "Front Mount Assembly". It mounts to the front of the frame, and the stabilizer arms to the posts attach to it. It also has a couple of hose brackets that hold the hydraulic hoses from flopping around. I did look around, and none appear to be available...Big Giant Surprise. I can't imagine anyone parting it out, even IF they knew what it was. But I pretend to be a welder and have Fab skills,
(Sorry, that should have read Fab Equipment), So I'm sure I could Hack one together if I had measurements. The grainy B&W photo in the manuals make it look very simple (Hahahahahaahahahah).....Anyways, is there anyone that would be willing to take a couple color shots And Measurements of their "Front Mount Assembly"?
Or rough estimates, then I can Make up something clos, and tweak it after its installed.
It appears to be the Ark style Loader, with the catalog number of 97-40FL-01. The actual part number of the bracket is: WheelHorse 260932 (part #36 in the pix)
Again, it looks like it attaches to the front of both Frame rails and loops around the front. It attaches with 4) 3/8" bolts and would have the hoses attached to it. It looks like it loops close to the front of the frame, meaning the mule drive would have to be removed, maybe even the Attach-A-Matic front bracket too. And its job is to give the Brace Arms a place to attach to.
Wish I had more info to give,
Can anybody help me out?
Thanx in advance, Have a Great weekend
Jay
I'll accept any form of communication, Calls, Texts, Emails
781.630.0338
By chompinthebit
I mostly retreated a picture from the 1961 dealer sales flyer I have that shows a lineup of optional accessories.
the accessories are the suburban fender and tool box option, tombstone weight, stepped foot rests, and seat hinge.
I have not seen another seat hinge like this besides the one I own.
The sign I show in my pic is also the hard to find circa 1961 plastic sales and service sign that is also pictured in the same paperwork.
By wh315-8
So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
