BigRedGrizzly
1970 GT14 Resto
BigRedGrizzly
19 hours ago, ztnoo said:
Check the specific gravity of your battery.
It may not be charging well or holding a charge for long.
Got to have enough amps available to spin the resource absorbing starter.
Ok. I didn't check the specific gravity but the battery is charged to 12.57.
I came home from work and cleaned where the starter mounts to the engine with a wire brush. Also cleaned the back of the starter. I mounted the starter and tried to jump it directly off the battery using jumper cables. Nothing. See the vid.
So, I disconnected the starter from the engine again and tried it. It WORKED!
So.. I'm lost. I painted everything so I wonder if I insulated a ground somewhere. Could it be that the engine sitting on the newly painted frame? I don't think so.  I'm anxiously awaiting advice.
Thanks guys.
Aldon
Yes.
It could be that. Use some aggressive star washers on one corner of the engine mounting.
You have proven you have ground issue.
  • Like 4
ztnoo
10-4 on an insufficient ground.
roadapples
I use star washers and dielectric grease on all grounds...
BigRedGrizzly
Ok... Great advice, all. If I understand the concept, the sharp edges of the star washer will pierce the paint and make direct contact with the frame. I guess I can do my best to scratch some of the frame paint off where the motor mounts to the frame as well as a star washer. I hope this  does the trick.
tbarnhart
Just a comment on the "hammer trick". Yes, it does sometimes work to jar on the starter a bit to get worn/sticking brushes to contact the armature and get it going. It really fixes nothing, just temporarily gets the thing cranked. It's also a really bad idea on a permanent magnet motor like the Kohler starter. If you break one of the magnets, you've basically ruined the starter beyond economical repair. Older automotive starters didn't have permanent magnets in them and could tolerate a bit of banging, but a lot of the newer ones do. That's a trick that is best used only as a last resort. Kinda like the little proverb that we often quote around our shop-"You can't ruin a rotten egg". Once its truly rotten, not much can make it worse, but until then, consider well if you may be doing more harm than good.
  • Like 3
RubyCon1
try using your jumper cables test again, but instead of attaching the negative jumper to the hood support, connect it to one of the engine head bolts.
953 nut
Move the ground cable to one of the starter bolts.
On 8/28/2016 at 7:03 PM, 953 nut said:
Have you tried moving the ground cable coming from the battery negative to one of the starter bolts?
oldredrider
Moving the ground to a starter bolt is fine. But you will still need a ground to frame for lights and such to work. Maybe run an extra ground wire from frame ground to starter bolt.
BigRedGrizzly
Ok guys. The the ground at the engine head bolt. No dice.
Next test. Ground to motor mount bolt... DICE!!
Tuneup
Hooray! Very odd that the head bolt would be different than the case bolt. It's the same chunk of cast iron. A cheap DMM would have isolated it more quickly. Disconnected battery and negative terminal to the starter body. Even the Harbor Freight cheapy DMM would work for you. If, after the star washer treatment, the starter is still intermittent, take it apart and give it a cleaning and brush inspection. I had to do this on mine and am glad I did. It was already missing a tooth and part of another so a cheap fix for that. Oh, the regulator gave out so that one you found on eBay has so far been just fine.
953 nut
:handgestures-thumbupright:  Getting closer! The problem you ( and lots of others ) have run into is that paint is not a good electrical conductor. You have done a great job painting everything, but paid the price when it came to electrical connections. I was a bit surprised the head bolt didn't work as well.
BigRedGrizzly
Alright fellas... Another test. I put the star washers under the engine.  See the result in the vid.  So, should I Just run a ground from the motor mount bolt to the starter mount bolt?
ztnoo
What do you have to lose trying that idea, but your time???
BigRedGrizzly
Ok. So I tried this... It didn't work either..
16 gauge wire ground from motor mount bolt to starter bolt.
RubyCon1
your issue is between the engine block and the battery negative terminal - not between the starter and the engine block
  • Like 4
953 nut
16 gauge is only good for abut 10 amps; your starter draws about 50 amps. Buy a new 6 gauge cable and run it from the battery negative terminal to one of the starter bolts!
SylvanLakeWH
:text-yeahthat:
I had a different ground problem, but essentially I ran a "redundant" ground and it worked like a charm...
BigRedGrizzly
Lol... I guess I should probably get some 6 gauge wire and run it from the negative terminal to one of the starter bolts..:text-lol:
Thanks, 953
Edited by BigRedGrizzly
Tuneup
Cut to the quick. Replace the negative lead with a nice new one - not expensive. Attach it from battery to the starter bolt at the engine. Your problems will be solved. If not, you're back to the positive leads and ensuring they're fresh. As they age, they begin taking some of the charge from the starter and will become nice and toasty warm.
RubyCon1
quick check
using your test light with the clip lead attached to battery POSITIVE.
any place you touch with the probe and the probe lights, that spot will be grounded
no light = no connection to ground (battery negative terminal)
  • Like 3
BigRedGrizzly
1 hour ago, RubyCon1 said:
quick check
Great tip Rubes.. Makes sense. I will keep that in my pocket. Regarding your previous post. I should have realized the ground issue was between the engine block and the ground terminal on the battery. In electrically challenged. :text-lol:
Aldon
You may have done so but I hate to assume in situations like this. Make sure the area under engine between frame and engine allows continuity. When I painted everything including engine, I cleaned all threads with tap to assure that through bolts which connect to cables had a path to ground.
Edited by Aldon
  • Like 4
BigRedGrizzly
Ok fellas.. Here's the deal...
I used a spark plug tester to make
sure I am getting spark. I am. It looks good. I also learned how to use that power tester backwards to check for ground. Thanks to Ruby. I also learned how to use my digital multimeter to check for continuity.  I put it on the audible setting and began checking. The solenoid has a good ground as does the motor mount bolts. Oddly enough it seems as though the engine itself does not have a ground. It might now that I ran the negative cable to the starter which is attached to the engine.
I have the old regulator if anyone is handy enough to fix the broken terminal. Anyone can have it. I'll mail it to you. It's a Repco 10 Amp.
So I just turned the key a few times. No start. I understand that it takes an while for the fuel pump to be primed to provide
fuel to the carb bowl. Is there any way to speed this up? Maybe poor a little fuel down the tube that provides fuel between the pump and the carb? I saw someone use a marine fuel tank/line bulb to help prime it.
RubyCon1
another concern regarding the non grounded cylinder head bolts
if they are that corroded where they are electrically non conductive, the threads may be so corroded they would not have taken the proper torque and tightened up falsely in the engine block
this could lead to head gasket blowout issues in the near future
  • Similar Content
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
    • swisstrac
      By swisstrac
      looking for info/help re securing a front wheel bearing/race for  GT14/ 1971;  any info would be much appreciated..
