BigRedGrizzly
1970 GT14 Resto
Fun Engineer
Nice job and good idea big red. You did a great job keeping overspray off the tire.
Bert
Looking good:handgestures-thumbupright:
SylvanLakeWH
So that's how you "mark" your cards...:ph34r:
:ROTF:
Great idea! Looks perfect!
  • Like 4
Achto
Cool trick! I've been painting for years and I've never seen a card trick like that.
DennisThornton
Shucks!  I like it!
BigRedGrizzly
Hi all... Reassembly is beginning. I still have some painting to do, but today I mounted the front tires and connected the rear to the the frame.
it was so hot here in NJ today. Oppressive, I tell you... Just couldn't get much work done. Needed Air Conditioning immediately..
Tomorrow I'm going to pickup a 42" snow plow. It's my understanding that it is a long frame plow but may not fit a GT14 without any modifications. So I may be doing a thread on that in the future of things don't as easily as I would like.
Edited by BigRedGrizzly
  • Like 7
BigRedGrizzly
Hi all.... No major update here... Still painting. All the wheels and tires are done.. Basically all the fenders are a painted... Just have the dash and the heavy nose left to paint. I'm looking forward to getting the front axle mounted so I can at least have a rolling chassis.
I have painted over the grease zerks so I will have clean them up to be able to use them. If it becomes a problem I suppose I can just put new ones in.
Here are a few pics of the snow plow I got.
  • Like 7
Aldon
Did you add bracing to support the fenders? From the angle it's grd to see for certain.
BigRedGrizzly
Unfortunately, I did not. I didn't even get them welded/repaired  yet. The local welder has blown me off 3 times so far. My time frame doesn't allow me a lot of down time. It will be addressed but will have to be done at a later time. I hate doing things that way but... :(
BigRedGrizzly
Continuing with the reassembly. I am happy to have it rolling now so I can move it in and out of the garage. These past couple weeks it's felt like a oven in that garage.
  • Like 5
Aldon
High heat and humidity make working on tractors tough right now and it takes real resolve to push through my minds thoughts of sitting in AC and relaxing. But I can't keep kicking the can down the road. There is always some reSon to procrastinate! LOL
BigRedGrizzly
Hi Fellas... I managed to get a few nor pieces put together today after work. I'm heavily relying on all the pictures I have taken for reassembly. There is a lot going on in that tunnel and referring to pics makes it much quicker. I'm trying to decide whether to remake the wiring harness or just use what I have. The existing seems to be in pretty good shape but I remember reading someone re did theirs and used marine grade wire. I'd like to have that.
My engine is very greasy and dirty. I suppose I will have spray it with mineral spirits and wire brush it. Then power wash it. Then I'll paint it the best I can.
Here are some pics from today.
  • Like 6
Aldon
I went route of marine grade re-wire. If your wiring is good then it is a toss up as I don't think the wiring takes much abuse. However, the connectors seem to reach a fatigue or corroded state so you may want to consider new crimp connectors.
BigRedGrizzly
Ok.. Definitely will consider the connectors when I get a closer look. I'm starting to get to that point now. I need to start getting the wiring into place here soon. I worked on the tractor pretty early this morning. I had my hands dirty by 7:15AM. I knew it was going to rain around noon today so I got an early start.  I'm glad I did because as 10AM rolled around it became extremely hot humid. Unbearable. The paint doesn't hold up well either. Easily scratches. Soft.  I got pretty much all of the tunnel back together and lubed the heck out of everything I could as it was assembled.
Heres some pics from today.
  • Like 5
Tuneup
Yeah, it's the only negative of the rattle can today - lack of hardener. Makes it flow nicely but takes forever to harden. Mine's the same - Rust O'Leum Regal Red. If I tackle another one, I'll learn to run a mix and spray it all the pro way.
BigRedGrizzly
Hi Fellas... I was in Walmart this morning picking up some engine degreaser when I noticed the display of oil filters. I was going to pick one up as I plan to replace the oil in the rear. I started searching the forum and my manual and found a part# that looks like Toro doesn't have anymore. What are you all doing for the replacement filter?  Is there an after-market filter that we can use?
oldredrider
NAPA Filter #1410 is the one you need.
BigRedGrizzly
Thanks, Oldredrider...:handgestures-thumbupright:
I sarted on the engine today. That is one greasy horse heart.  Thing we're coming apart nicely until I had to remove the perforated fly wheel protector. Man O man where those suckers tight and locked up. I used some PB Blaster, hand held impact screw driver, large dead blow hammer, and the always (or mostly) successful tool, the vice grips.  I eventually got everything off and began degreasing. I used engine degreaser and odorless mineral spirits. It seemed to clean up pretty well. As I was cleaning and disassembling a 22LR round fell out some where. I quickly disposed of that. I live in NJ. If some one catches wind of a round at someone's house the damn SWAT TEAM and FBI will raid your house.  Lol.... Not really.. But NJ is unreasonable.
I managed to clean one side up pretty good. It was the dirtiest/greasiest side. The gasket between the carb and the engine is wasted. I'll need to get a new one some where. I'll disassemble the carb and soak it in that carb cleaner that comes in a 1 gallon paint can. I think it's called Berryman's carb soak. I'll let it sit over night and reassemble. I'm also going to replace the fuel lines. They are pretty hard and seem like they are going to crack at any minute.
BigRedGrizzly
Well... I got into the carb today. It was pretty nasty. I don't know how this thing ran as well as it did. I disassembled it and put it in to soak for 24 hours in ChemDip.
We will see how clean it looks tomorrow when I take it out. I need to order a rebuild kit anyway because I need the bowl gasket.
I'm think about getting one of these two and the carb gasket.
Tuneup
That chem dip is the bomb. Cleaned a cycle carb with that stuff. Came out like new. It will destroy anything not metal so be sure the grommets and felt seals are taken out - maybe the choke and throttle areas. eBay is always your friend!
WHX??
Agreed ..just did a plugged up little walbro from a weed wacker the other day and good as new. And they say its not as good as it used to be because they had to make it envronmental friendly, the old stuff musta been really something.. never be with out a can of it!
BigRedGrizzly
Hi Fellas... I pulled the carb out of the ChemDip around 5:30 this evening. I rinsed off with water and sprayed all the parts down with carb cleaner and blew out all the orafices. Looks pretty clean to me. I learned that this a Walbro 4705312 carb. It's my understanding that the Carter Carbs are much better. If this one craps out I may purchase one from EBay.
Here are some pics of the carb after they have been cleaned up.
Tuneup
A little Brasso will make those needles gleam. It's all about the 'little things'.
953 nut
A bit late for this one, but file this away for reassembly time. High temperature thread-locker was used on these machine screws; warming them up with a torch will break the bond and you can break them free while warm. When it goes back together you will want to use some.
  • Like 4
  • Similar Content
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
    • 12 hp Kohler
      By 12 hp Kohler
      Saw a gt14 for a really good price on Craigslist yesterday went and looked at it last evening, ended up buying it . It’s a 68 or 69 gt14 but I’m not exactly sure which. It’s in decent condition and seems to be complete. It has a really nice complete three point hitch and a really nice three point tiller. I didn’t think the seat and muffler were original but I looked at a manual and it turns out they are. I’m gonna try to get it running for the big show but if I don’t I will still take it. The best part is I bought it from a super nice guy that knows a lot about wheel horses. Some of you might know him, his name is Less, sorry didn’t catch his last name. He has been going to the wheel horse show since the beginning and personally knew Cecil and Betty Pond. He used to have 74 tractors but he narrowed it down to his favorite three. Overall it was a really good day. I got to meet a really nice guy, get another tractor and hear some good stories. Here are a few pictures of the gt14 and tiller. I am gonna start working on it this Sunday.
      Tractor or serial number
      Tiller serial number
    • swisstrac
      By swisstrac
      looking for info/help re securing a front wheel bearing/race for  GT14/ 1971;  any info would be much appreciated..
