Fun Engineer
Clevis/slot hitch adapter position
Fun Engineer
So what's the correct way to install this in the slot hitch?
#1 looks right to me but I've never used one.
This way?  #1
Or #2
Edited by Fun Engineer
Forgot pictures
Shynon
This way?  #1
Or #2
Door number 1
ol550
Borrowed one of Wheelhorseman1000's pics.
Achto
Looks to me like it would depend on where you want your hitch height.
Phatboy
That particular hitch you have needs to have the bolts on top and yes you need that piece pictured in ol550's picture the stops the implement ie.. Brinly plow from swaying back and forth,, and keeps it straight,, if you dont have it your plow will not function properly .. Example it will not turn soil properly and may rise up out of the dirt because the plow share will not be flat and will either dig to deep or not deep enough..hope that helps..
Edited by Phatboy
Fun Engineer
just needed to know the proper orientation of the hitch. If it's installed as Phatboy and Shynon suggests, the metal angle sits awkward on the angled hitch gusset. It sits flat if installed as in photo #2. But without the metal angle it "looks" correct in photo #1 with bolts up.
Thanks everyone for your help.
CasualObserver
It goes flat side up.
By the way... the adapter is a Brinly HH-180... it's in the manuals. I scanned it years ago from an NOS one I have.
Fun Engineer
Thanks Casual. I didn't think of looking in the manuals section.  I'll have to make a copy. Interesting that it is installed differently from a Ford or Jacobson.
