Pilgrim 27 #1 Posted June 7, 2016 Hi all, I recently purchased a 420-LSE in pretty rough shape. The transmission dipstick tube was busted off, so I purchased a replacement. However, I am unsure how far to screw in the new tube to get the proper transmission oil level. Does any have any pictures or dimensions as to how far I should screw the tube in? Share this post Link to post Share on other sites
cleat 6,412 #2 Posted June 7, 2016 I always screw mine in until they are tight. It is a tapered pipe thread so it will tighten as you screw it in. I use a medium sized adjustable wrench (one that will just open enough to fit on the square on the bottom of the tube) as the proper wrench is too big to fit in. You want the tube tight enough to keep out dirt and water but of course not so tight that you strip or break it. Share this post Link to post Share on other sites
Pilgrim 27 #3 Posted June 7, 2016 Thanks Cleat. I screwed mine in until I was afraid to go any more. The threads are flush with the top of the hole. Do you seat yours so that the square portion is tight against the transmission? Share this post Link to post Share on other sites
cleat 6,412 #4 Posted June 7, 2016 No, just where yours is now is right. Don't force it. Share this post Link to post Share on other sites
Pilgrim 27 #5 Posted June 8, 2016 Great. Thanks again , Cleat. Share this post Link to post Share on other sites
