JerDecker63
Looking for information on Kohler Engine
JerDecker63
I recently pulled this Wheel Horse out of my Father-In-Law's garage. He said that he picked it up some years ago at a yard sale.  I am interested in getting it running again but as can be seen from the pictures the carb is missing.  I am not having any luck surfing the web trying to figure out where to get parts.  My Father-In-Law said that the engine ran but he pulled the carb for another project and never got back to this one.  If anyone could help point me to a service manual I would greatly appreciate it.
B4DdvPjdDsBBYlL_vrNgzI1NtAs4tZaqljoTRDqy
PNYKmUk4P0WZVF_Uxz2iQRm98SYdtbK-e3FQla0F
Cy5jMHe9sh_jZroMAyJ4G5kWNdeO9eiynYLtCw4h
Muffler will be needed once this thing gets fired up!!
JAinVA
JerDecker,
   Carburetors for Kohlers are plentiful and cheap on E-bay.New or used,any horsepower.The muffler may be more of an issue inless you go with an aftermarket unit.Same source.Luck,JAinVa
Edited by JAinVA
KC9KAS
@JerDecker63 Photos did not open for me either.
:WRS:
JerDecker63
Thanks for the feedback on the photos.  I will try to load them in a different format.
Richard: Based on the links you provided I am guessing that this is a 4 hp engine. ??  I am going to pull the head off and will measure the bore to verify.
3 hours ago, 953 nut said:
953 nut
:text-coolphotos:  The information tag is missing from your engine, but if you measure the cylinder and the stroke you can determine the size.
Kohler Single Cylinder Engine Specs _ Torque Values and Sequences for Fasteners _ Identification & Torque Settings of Most Commonly Used Grades of Bolts (1).html
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
