rexman72
restore homemade loader
rexman72
ok great to know.here are some pics of the loader.We are building new arms for the loader and cut out some of the old parts.I ordered some cylinders to from the post you sent me.
rexman72
this is the subframe attached to the tractor
rexman72
I have a couple of questions for you guys.
1. can i use hose clamps on the 3/8 pressure line from the pump to the hydraulic spool?
2.what kind of oil should i use for the bucket loader?
wallfish
1. No, it is high pressure. Everything except the return (after the spool valve) and the suction hose TO the pump are high pressure.
2. Hydraulic oil-- It is designed to let the air bubbles out quicker and dissipate the heat better. I bought a 5 gallon bucket from Tractor Supply but you can find it in most auto parts stores too.
I highly recommend you Google-- "hydraulic oil accidents" and you will see exactly why caution must be taken when dealing with fluid under high pressures. It made me pay extra attention to what I was doing!
Edited by wallfish
rexman72
ok thanks for the info
rexman72
On ‎6‎/‎3‎/‎2016 at 10:21 AM, WNYPCRepair said:
Northern Tool has a few. I built my own loader with this pump and a 6" pulley, but it might be just a bit too powerful, the bucket moves a little faster than I would like.
http://www.northerntool.com/shop/tools/product_200329712_200329712
this is the pump that I bought for my loader.The problem I am having is that I bought a pulley with a set screw that goes on the pump shaft and the set screw is to big and the pulley woobles on the shaft and the belt comes off.Is there a pulley you guys recommend  that will fit on the shaft of this pump or should I try to modify the pulley  I have to the pump shaft?
WNYPCRepair
I did the same thing. That pulley will not work, you need these:
http://www.mcmaster.com/#9859t1/=11w85yl
http://www.mcmaster.com/#6209k215/=11w86up
This is what I got, from surplus center
Edited by WNYPCRepair
rexman72
7 minutes ago, WNYPCRepair said:
ok I am glad to know I am not the only one that had this issue.The one you have is 6 od  for the pulley.Do they have a 4 to 5 inch pulley?
WNYPCRepair
1 minute ago, rexman72 said:
http://www.surpluscenter.com/Power-Transmission/Pulleys/Split-Taper-Bushed-Bore-Pulleys/
I used the 6" because I used it on a loader for an XI series. The PTO pulley is about 6", so I wanted to be close to the same size.
WNYPCRepair
2 minutes ago, rexman72 said:
ok I will be ordering this and thanks for the good info because I was trying to figure this out today
All thanks go to Andy, without his help, I would not have been able to do as nice a job as I did on my loader.
