Similar Content
By tomabrown77
my 1067 stopped moving; limited slip had worn out long ago; now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance. Enough to tell me shift lever is actually changing gears.
I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt transaxle if someone has one they would part with. And any advice on opening up the transaxle and looking inside . Or where i can find parts to rebuild it myself...
ps i was on forum about 5 years ago, forgot my username so i joined again
By Mikey j
Hi everyone, I have a 1969 raider12 6speed trans, Thant I’m going to change the oil in. But I don’t have a dipstick how do I get the two quarts in there? i tried filling from the side port only got about 700mils in. Thanks in advance!
By BMW1
I have not had to do this before and want to make sure I'm doing it correctly.
Picture of bearing and seal is attached.
Is the bearing supposed to fit in the groove of the oil seal or is the seal supposed to flush against the bearing? I think the latter is correct?
Thanks
By BMW1
We are putting this transaxle back together and noticed the parking brake pawl seems to be in bad shape.
The part is NLA but someone said it could be mig welded and filed.
I have never seen what it should look like. Is there supposed to be a "notch" in the pawls or should the weld be built up and then filed so there is no "notch"?
By Barcaskey
I have a D-180 that broke an axle I have got all new parts and have removed transaxle from machine. The 2 parts I am missing for re assembly are the metal screen with magnet for inside trans and a new gasket from transaxle to pump. I have done some looking and can not find these parts. I have the old screen but the rubber gasket on the end of it has some rot and is apart from the screen. The gasket is still in place but i would feel better putting in a new one before re build. Thanks for your help
