fitter 4 #1 Posted May 26, 2016 I was cutting the grass yesterday and when I stopped and put it in reverse the shift lever came out and now it's in neutral. Any help would be great. Thanks! Share this post Link to post Share on other sites
doc724 925 #2 Posted May 26, 2016 Common problem. Take off the tunnel cover and lift up the rubber boot that went around the shift lever. You will see a little setscrew there. Put the shift lever back into the place where it came out and screw the set screw into the ring around the shift lever where there is a small indentation. Not too tight-you will know if it is too tight as you will have difficulty moving the lever. Tighten the jam nut to prevent the set screw from moving again. Reinstall the boot and tunnel cover. If you search this forum, you will find lots of postings on this, many with pix 2 Share this post Link to post Share on other sites
OHRob72 88 #3 Posted May 26, 2016 Here is a drawing from the manual to help you out. Shift Lever.pdf 1 Share this post Link to post Share on other sites
Racinbob 11,265 #4 Posted May 26, 2016 (edited) That's a good explanation on how to do it. Make sure your shifter forks are in the neutral position (use a screwdriver). They will look like this. Tighten the setscrew just until you start feeling resistance as you shift through the gears. Then back off just a fuzz and hold it there as you tighten the lock nut (not shown in the picture) Edited May 26, 2016 by Racinbob 2 Share this post Link to post Share on other sites
fitter 4 #5 Posted May 26, 2016 Thanks guys, I'll give it a shot. Share this post Link to post Share on other sites
fitter 4 #7 Posted May 26, 2016 UZ guy"s are the best. Made my own set screw, grinding the end. Cut the grass again. Now on 2nd 6pak of bud on ice. NIce ! 2 Share this post Link to post Share on other sites
