Harley Schlinger 0 #1 Posted May 25, 2016 I have a 1974 Wheel Horse 160C Hydro. 16 HP Tractor that I perched from a guy had everything working just fine have been using it for over a month now and yesterday I started it up and went over to my Friends place with it and shout it off and when I started it the Transmission will not work it is a Hydrostatic Transmission Transaxle it is like the pump just quit the lift cylinder will not work nothing oils is full new filter and new oil, so is there a bypass valve or something I am over looking that just got stuck or would the pump just go out like that????? it is a 1974 Wheel Horse 160C Hydro. 16 HP Tractor Model # 1 0480 9 Serial # 1012329 Engine Model # K341S Spec. # 71128S Serial # 5301747 Hydro-static Transmission Trans-axle Model # 90 1140 Serial # 03-1P 364212 Share this post Link to post Share on other sites
daveoman1966 3,811 #2 Posted May 25, 2016 unlikely that the pump would suddenly quit. You MAY have a linkage problem where the cam and cam follower are not working correctly. OR... it MAY have separated and broke the cam plate, due to a broken trans mission mounting plate. That would allow the tractor to flex in the middle and break the nylon cam. Also look at the pump pulley...is it splined or use a woodruff key. If the latter, maybe the key sheared off. Share this post Link to post Share on other sites
953 nut 57,985 #3 Posted May 25, 2016 Is the belt still there? How about the engage/disengage lever position? Share this post Link to post Share on other sites
can whlvr 993 #4 Posted May 25, 2016 good advice above,they do just quit working,mine did,no warning,no sounds,just quit workin Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,251 #5 Posted May 25, 2016 Service manual has a diagnosis procedure in part 1 Garry Share this post Link to post Share on other sites
KC9KAS 4,744 #6 Posted May 26, 2016 @Harley Schlinger Share this post Link to post Share on other sites
pfrederi 18,335 #7 Posted May 26, 2016 If the lift cylinder will not work it is not likely to be the cam plate...more likely a belt issue or the input pulley has started slipping on the pump shaft.... Share this post Link to post Share on other sites
