moe1965 749 #1 Posted May 25, 2016 I have a raider 10 tractor and I bought a raider 12 for parts. I noticed that the axle is a little longer than the one on the raider 10 and the shaft is 1 1/8. The shaft is one inch on the raider 10 trans. Are there any other difference between the two. Share this post Link to post Share on other sites
953 nut 56,201 #2 Posted May 25, 2016 That would depend on the year, some changes over the years. Some years they both used the same, some they were different. Take a look at this list. wheelhorseallyears.pdf Share this post Link to post Share on other sites
stevasaurus 22,914 #3 Posted May 26, 2016 Your Raider 10 with the 1" axles is a Wheel Horse #5086 transmission. It has a 4 pinion differential. I think your brake drum is on your cluster gear shaft also. Your Raider 12 has the 1 1/8" axles. It is either a Wheel Horse # 5060, 5071 or 5073 transmission. All 3 of these are 10 pinion, limited slip differentials. The brake drum on the 5060 and 5071 would be on your 11/44 toothed gear...the hole closest to the axle housing. The 5073 would have the brake drum on the cluster gear shaft...the next hole toward the front of the transmission. Share this post Link to post Share on other sites
