Road-Track
C-145 A drive belt size?
Road-Track
I blew a drive belt on my 1983 C-145 hydro and the belt measured 82". I looked up the correct belt and have seen many different sizes called out.
Is 5/8" x 81" correct?
Is 5/8" x 81.5" correct?
or
Is 5/8" x 82" correct?
I also saw 98" using the same wheelhorse number????
Any help would be appreciated,
Thanks!
stevasaurus
I see what you mean about different sizes, especially through the years.  After looking at Gerry's notes though, plus I found one chart that went along with Gerry's notes also...1983, C-145 auto, 01-14KE04.  I would try the #108501 belt...5/8" x 81.50.  :)
jay bee
I have a 1983 C-145 auto, 01-14KE04 and I am running a 5/8" x 81" belt and it seems to work just fine.  Hope this helps...
Jim
gwest_ca
This pertains to the Sundstrand models
The 7478 drive belt is 5/8" x 84.22".
They had a problem at one time with this belt being too short on 1977 and prior models but has since been corrected.
Garry
Adding
The difference for the Eaton models is the twin cylinder models use a different belt than the single cylinder models but the shared parts lists don't tell us what uses what.
1980 was the year they used both Eaton and Sundstrand hydros.
The 1983 C-Series drive belts have been added to this page
Road-Track
Thanks!
    I went with a 108501 WH belt:wh:. I believe the one manual I found on RS said they were 81.5 inches.
ohiofarmer
 While you are changing the thing, check your idler pulley shaft where it goes through the frame of the tractor close to the pulley.. Adding oil at the bushings helps prevent wear. Mine wore through at the bushing[if there ever was one], and i had to rebuild it.  When the bushing area gets worn, the transmission drive belt vibrates causing it to wear. Instead of just rotating on an axis, the idler pulley looked like a paint shaker.
 The idler pulley on my 520 operates with a spring. i have a 416-8 that operates with a piston shock absorber and that would be a better system to cut the vibration.
Happy trails.
  • Similar Content
    • cheesegrader
      By cheesegrader
      About a decade ago, I bought a conversion kit here to remove the column drive lever and convert to a foot pedal for a 520h.
      I would like to convert a second tractor, and I need to replace one of the linkage bars on the first one that has cracked, but I can't find the vendor any more.
      Does anyone remember who made this awesome mod, and where I can find them?
    • randyh
      By randyh
      What size belt do i need for a 48 inch deck on a 520 hc
    • giant_g2
      By giant_g2
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • Doug B
      By Doug B
      Hey guys,I have a dilemma I need some help with. I have a 1969 GT 14 that I replaced the transmission and pump on. For about 2 weeks afterward everything worked great, but while mowing at a pretty good pace I noticed a shudder and the tractor slowed a little but not bad. The more I rode it the slower it got until it barely moves. What stumps me is the hydraulics are still very strong,as in I can back the 3 point under the bumper of my truck and if you lift the arms all the way up the front wheels of the tractor will clear the ground. Have checked the tow valve and checked the internal filter,but no luck. I have also checked and replaced the forward and reverse bypass springs and the lever is moving the cam to full travel, forward and reverse. Any help would be appreciated.
