REDMRED 0 #1 Posted December 17, 2008 hi i have a wh 550 with out engine, I found what looks exactly like a h55d 2113, except it has no electric start . Now if it is identical what should be the shaft size and pully type? where could i get this pully, one last question , can i eventually convert this engine to a electric start. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #2 Posted December 18, 2008 Shaft size should be 3/4". The 2 pulleys were 2 Share this post Link to post Share on other sites
Michael Bullington 5 #3 Posted December 18, 2008 TT is right on the money!!! some engines dont have the holes for the starter,,,also the shrould needs a cone for the starter,,,then if you want a charging sytem thats a whole nother chapter... let us know Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted December 18, 2008 hi i have a wh 550 with out engine, I found what looks exactly like a h55d 2113, except it has no electric start . Now if it is identical what should be the shaft size and pully type? where could i get this pully, one last question , can i eventually convert this engine to a electric start. My 502 has an H55 (recoil start) on it. The block has the holes for the starter on it. To convert to electric start you would need a starter, flywheel with a ring gear, and a fan housing with provision for the starter. Then you'd need all the charging system stuff too. Maybe H60 stuff would fit on the H55? A lot of parts will interchange... FWIW the crank size on mine is 1". (Front engined tractor with the 3 V PTO pulley. Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #5 Posted December 18, 2008 Is your engine an HT55C, Mike? Share this post Link to post Share on other sites
sorekiwi 761 #6 Posted December 18, 2008 Is your engine an HT55C, Mike? Just went and got the numbers. Wish I hadnt now.... HT 55A 3088 P 11K23. Looks like its a mongrel, huh. That might explain the bolt on exhaust manifold as well. The HT55C's had a 3/4 shaft? Share this post Link to post Share on other sites
TT-(Moderator) 1,131 #7 Posted December 18, 2008 I'm guessing that the HT's are heavier than the H's. (like the H vs. HM Tecumseh equivalents) My 32E Lawn Ranger has an HT55C 3089 P with a 1" crankshaft and the 3 groove pulley - just like the 552 tractors used. (which makes sense because the 1962 Lawn Rangers are basically 502/552 models with small wheels & tires and different toolbox/fenders.) I'm pretty sure the H55B & D's (used on the 550 & 551 models) had a 3/4" crankshafts. Share this post Link to post Share on other sites
Michael Bullington 5 #8 Posted December 18, 2008 Yes TT I would say you are correct...I had a H55A off a 550 once that had the 3/4 shaft :hide: Share this post Link to post Share on other sites
REDMRED 0 #9 Posted December 19, 2008 Thanks for info, im picn engine up tommorow. Im gonna post pics. also did any 5.5 lausons come with a 1inch shaft Share this post Link to post Share on other sites
