Thisguyisnew
Mowing with 1977 C-160
Thisguyisnew
Still amazing to think this tractor had been sitting as long as it had before I got it. Been mowing ever since, of course had to put work into it but nothing major. The grass it's able to cut enables me to mow  on my schedule with one pass. Saving me so much time. It came with a plow and tiller but don't think I want to be using those. For a couple of reasons... One don't have that much of a need right now, and two don't want to put to much wear on a thirty-something year old trans. Mows like a champ want to keep it that way. Am I wrong?
  • Like 6
Wishin4a416
Welcome to Red Square and I wouldnt worry about the tranny. Now if was one of those new models with a 15 pound pot metal tranny, I would worry.
  • Like 7
JERSEYHAWG /  Glenn
Newguy, welcome to the red square . How about some pictures, best of luck.
Glenn
Thisguyisnew
Thanks and I kind of wanted to try them out myself but still would want to baby it. When I first mowed I actually set the throttle way below max RPMs and it still cut heavy grass with no problem. Had some vision of it blowing balance gears because of it  sitting for so long. Now no worries. I'll try and get some pictures but every time I see it now it's just to mow... no real fan fare and I know that it can clean up nice.
Tankman
Sounds like a dedicated Horse for mowing.
Another Stallion, just in case you want to garden, tiller Horse.
Ok so now a Horse for the plow, necessary, just in case! Gotta have a plow Horse of course!
So far so good! You might like a Horse for a snowblower. You're going to need that, maybe but, just in case!
Your herd of Horses can share the gas cans!  :rolleyes:
Edited by Tankman
  • Like 9
chorusguy
Great machines.  I have several if them.  Be careful about running it at low Rpm the engine is designed to rev at 3600 it relies upon the high rpms for lubrication.  If you run it low you might destroy it with your good intentions.
Also, I think I read somewhere that somebody said that if all the things we do with our little red wonders, that mowing is one of the toughest.
Ed Kennell
:WRS:    and to the WHA  (wheel horse addiction)  support group and half way house.
  You may only have one, but some of your comments indicate you have already contracted the dreaded WHA .
Tankman
High rpm's for air flow, don't need heat! :angry-nono:
Thisguyisnew
Boy you guys aren't kidding I did wonder where I could find another one of these for tilling and without even thinking about it. Spooky... also thanks for rpm advice but just so you knowI only did that really for the first mow kind of like a re-break in period at least that was the thought. I do know however it will cut tall heavy grass with no problem because I have kind of an obstacle course in a great many areas. Which brings up the turning radius. Awesome
elcamino/wheelhorse
Welcome to Red Square. The horses are built to work , keep the oil changed ,blades sharp clean the deck and let it work. They don't like to sit . Of course there are show horses . The true addict has a show horse and the same model as a worker.
can whlvr
welcome,and as replied already don't be afraid to use her,they are very tough machines,i have a couple of 160,s and I use them regular and hard,and you should run her wide open,for air flow and to keep her lubed,shes a splash oil unit,so don't run her too slow
TDF5G
:WRS:
Don't be afraid to work your Wheel Horse. That's what they were built for!
ericj
you don't say if you have a hydro or a stick, if hydro you must run 3/4 or higher rpms for the tranny to operate right and prevent damage
eric j
Thisguyisnew
It's a Hydro  Sorry that I did not mention it.
DougC
Hello and  :text-welcomeconfetti: .    Enjoy the forum!  :handgestures-thumbupright:.  Consider becoming a supporting member. Pictures are a breeze to post then.    :)
mabsoon
Welcome :) I say buy another C-160 and get rid of the tiller :)
Oh wait! :)
dells68
Oh oh.  Now I know I'm sick.  You just described me!  Fixing up one GT14 and getting ready to put another to use this morning;).  Is there any help for this addiction, or am I doomed?
TDF5G
There is no cure, only therapy.  Buy more Horses!
:lol:
mabsoon
:text-yeahthat: when do you want me to deliver the next C-160 :wh:?
Tonight at 9pm right?
:ROTF: :ychain:
How about Friday at 6:30?
Thisguyisnew
Now I get what you meant, 6:30 Friday. They are like potato chips really you can't stop at just one.
  • Similar Content
    • CHuls
      By CHuls
      *Estate Sale*
      71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
      Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
      Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
      Not sure what it's all worth together but, make an offer.
    • PMeadows
      By PMeadows
      Thinking about selling my 1974 C-160 and hoping to get a feel for interest. It has working hydraulics, front plow, single row rear plow, 42" belly mower deck, 55lb wheel weights. Runs fantastic, no smoke. Lights work, amp meter works, has plug in cigarette lighter (doesn't work). Left rear wheel cylinder has slow leak.
    • RJ Hamner
      By RJ Hamner
      The C-160 just wasn't running right. Started with new points, plug, filters.
      I had put an aftermarket carb on it but had found a good Carter N in the correct size so I rebuilt it.
      Got it started this afternoon and had it running at about half speed to warm it up so I could make the final adjustment to the carb.
      It purred along for about 4 minutes and just quit.
      First thought was "out of gas".  Looked in the tank and sure enough it was really low so I filled it up.
      Tried to start it again .....NOTHING
      Went and rechecked everything ....NOPE
      Got out the can of starting fluid...NOPE
      Pulled the plug and noticed the gap was ZERO.  Re-gapped and tried again.  Same thing again no gap.
      Pulled the head.  Looked normal.
      When I cycled the engine I noticed that the exhaust valve didn't fully retract.
      Was able to remove the exhaust valve with two fingers!!!!!
      Guess I am in the market for a new set of keepers and a few gaskets.
      The guys at McHenry's Small Engine Love Me
    • tractorman99
      By tractorman99
      Hi everyone,
      I bought a wheel-horse c-160 a while back, and did some work with it.
      One day the rear axle housing broke:
      I was thinking about changing the part or soldering the broken pieces.
      Does anyone know where to order this part? Or has any idea of the potential cost of a soldering job?
      Thank you in advance!
    • IthacaJeff
      By IthacaJeff
      I'm not really sure why I feel compelled to post this, and my daughter might kill me, but she finally got on the horse.
      It is a rule in the family that you cannot get your learner's permit for driving until you get significant seat time mowing.
      My 3 older boys had no hesitation, my younger 14 year old twin daughters have been getting some time, but 16 year
      old daughter has been reluctant to say the least. This has not been one of the forced chores, but a lesson in "If I
      want to do X, I'll need to suffer with Y".  Well, the other day I asked if she wanted to mow, same question as all
      summer, and I expected the same answer, "No thanks, dad, I'm good." But, finally, she agreed.
      Took instruction with great care, listened intently, and did a great job. The 416-8 is not the easiest thing to master,
      but she had no problems with the clutch, or keeping the tractor on a good mowing path. Got confident going
      around trees. It was awesome.
