Toolmanbill 34 #1 Posted May 18, 2016 There is a 315-8 for sale near me.i currently own a 314-8 1994 vintage.is there anything to be aware of with this 15 hp model? Share this post Link to post Share on other sites
oliver2-44 10,367 #2 Posted May 18, 2016 Be aware that it will soon be goneif you don't hurry up and go get it! Share this post Link to post Share on other sites
doc724 925 #3 Posted May 19, 2016 315-8 has many safety features that will drive you buggy. Otherwise a good solid machine. Engine is Command Pro (alum block with OHV and full pressure lubrication). Quieter than a Magnum. Mine (I have a 98 314-basically the same engine) has a small oil leak under the engine side plate on the PTO side. (cost reduction by Kohler to eliminate paper gaskets and use RTV). Like Oliver said-go get it if the price is right! Share this post Link to post Share on other sites
doc724 925 #4 Posted May 19, 2016 315-8 has many safety features that will drive you buggy. Otherwise a good solid machine. Engine is Command Pro (alum block with OHV and full pressure lubrication). Quieter than a Magnum. Mine (I have a 98 314-basically the same engine) has a small oil leak under the engine side plate on the PTO side. (cost reduction by Kohler to eliminate paper gaskets and use RTV). Like Oliver said-go get it if the price is right! Share this post Link to post Share on other sites
