![Furious](https://www.wheelhorseforum.com/uploads/set_resources_58/84c1e40ea0e759e3f1505eb1788ddf3c_default_photo.png)
Similar Content
By PWL216
Hi all. I have a 1277 that I pulled a loader off of. I’m not going to use the tractor and although it’s trashy, there may be usable parts on there that someone needs. Let me know what you need and I’ll see if I have it.
I’m in MA and plan on going (first time) to the Big Show. Also, if you need something from the MA area brought to the show, I’m your huckleberry
By Bostman67
1967 Wheel Horse 1277 - Kohler K301S, gas engine, belt driven, hydrostatic. I had it running recently but then attempted some electrical work. I also cleaned it up by sanding some rust, dirt and grime off body and engine. Some new parts were added like a new choke cable, ignition switch, head lights, spark plug, battery and battery cables. I have new seat and some other parts that I will never use if sold. The implements include a tiller, snow thrower, mower deck. I've never attached these items. I have some belts and pulleys that came with it when I inherited it. It's easily accessible for removal and showing.
IMG_1727.MOV
By CB1993
Hello. I just purchased a 1277 today and was wondering if there was any info on the mower deck. Is there a manual for this deck? What kind of belt is used? I have attached some pics. Thanks for any input.
By WHX??
@Achto and I took a little ride to title town this weekend to pick up this pair. Pretty much gave the seller asking price for the 1277 and he threw in the 1077. Both are far from pristine with the usual PO wonderments! Very savable tho. Both run and drive.
By JayB
My 1277 tractor has a Kohler engine but the ID tags are missing. Any idea how to determine what HP this is? Also what is the spark plug gap setting?
