Blue Delta
94' Toro Wheelhorse 416-H Mild Resto/Clean
Zeek
Nice garage floor!
  • Like 4
bds1984
My vote is for just cleaning it up and keeping it as is!  Well, maybe upgrading the seat, too.  Nice looking machine!
V-Four
Heck, that doesn't look so "Sad and Sorry" as you put it. (Or do I feel that way because I actually bought a WH in what seems to be much worse shape, although running and functioning) ;)
But seriously, that things looking good with just a cleanup so far. I cant believe the hubcaps.. nice.
mikekot3
Nice 416 tractor you have. I have a 416-8 manual transmission version that I upgraded the engine to a briggs and Stratton vanguard v-twin 23 hp engine.
WVHillbilly520H
Not to drift off from the thread but how do you like the Briggs conversion? Was it a S.E.W. kit? Fuel economy any better than the Onan? I'm sure 23hp is more than the original 16?  Wondering just in case my 520/P220 dies and instead of rebuilding repowering thanks,Jeff.
mikekot3
Hello Wvhillbilly,
Yes I like the conversion kit from small engine warehouse. It works well and the brackets included made the swap easier to do. If I put it in third gear and use full throttle I can do a small wheelie woo hoo !!   The fuel economy seems to be good.
WVHillbilly520H
Good deal I know it was a bit pricey but I'm sure a warranty on the unit and no worries over if the rebuilt Onan would hold up, 1 more question or 2 how does it sound compared to the Onan and any pics? Thanks Jeff.
Blue Delta
Dare I say I don't think I know of a Briggs engine that does not leak oil (even new ones), if it isn't leaking then there is no oil it, fill the oil to the correct level again.
Slightly back on topic, I am getting the head gaskets to de-carbonise the cylinders as the machine has done 467 hours (I know the hour meter works as I have put 2 hours on it playing around). I have not pressure tested the cylinders but pulling the heads off a 20 year old engine will let me see if there is anything lurking since I have no idea why you buy and expensive tractor and not use it (I see LT's at work that have 4 times the hours, they are wrecked though but half the age).
mikekot3
The Briggs engine sounds very nice and does not have that annoying hunting sound my old Onan engine had. It does not leak oil and I run Mobil1 synthetic oil in it.
cschannuth
Haha. This '78 Briggs doesn't use or leak oil.
  • Like 5
cschannuth
I should probably knock on wood...
Blue Delta
Your C-161 is a nice looking beast, shame we didn't get any black hoods in Australia
mikekot3
Nice tractor cschannuth I like tractor Wheel horses are made well and easy to work instead of the cheap crapola offered today.
Blue Delta
Small update, the LH hub has moved about 3mm off the axle and of course it doesn't want to budge, should I pull it?
cleat
3mm ?
I would not worry too much about that little bit. Just make sure the set screws are tight.
Blue Delta
Thanks Cleat, there is black pain even on the inside of the hub, almost like it has been like that for years
cleat
It's hard to see in this picture but the left side hub on my 520HC has a small gap as well.
The axles move in and out a tiny bit on all of my machines (even my truck) so I don't worry too much.
WVHillbilly520H
There's actually a "fiber" spacer between the hubs and the axle housing on both my 520s, I believe it's there to keep the hub from wearing on the housing unless someone knows otherwise,Jeff.
cleat
Mine have this as well. Kind of a plastic thrust washer.
Cole J.
Nice tractor, we used to have a 416-6 speed ... I think. I don't know, that was back before I got interested in tractors. Anyway we traded it and a green and yellow thing for a gravely zero turn, it was sad to see it go because it was a nice tractor it used to be my grandparent's. I know exactly where it still sits. At the dealer's grave yard slowly rusting away, sad really.
Blue Delta
So I finally dug my WH out of storage and finally reassembled it! - I had unfortunately mothballed it *forever*. I had moved to full time at my work shortly after pulling my tractor down which put the project hold, dragged on for a year to which I put all my parts in storage (got heaps of new parts during that first year), pushed the chassis around the garage as vehicles changed around it. I lost hope in that I would ever have it back together again as a complete tractor - even gave my hub caps out to a 260 series that I gave my grandparents.
This is just after I got it all out, I removed the ignition coil and tins from the engine - I had to guess a little but it all made sense in the end. The hardest part I found was putting the wiring loom back, since it was so long since I removed it (and I don't see any of these tractors at work) I had completely forgotten the correct routing. What is also missing is table full of parts in bags.
Just put the engine back in sheet metal was just sitting on the frame at that stage
Looking a bit better here (had the loom in) - still sporting the original Dico's.... (what is missing is that I had the tractor together shortly after this photo but didn't take any photos for 13 months - oops)
Second wind about a year on since the tractor was put together, brought the deck into work to asses how bad it was - I had stored the deck out under a tarp for the 3+ years since getting the tractor so I was expecting the worse, but it was surprisingly in amazing shape. I didn't clean out from the guards when I got the tractor so there was still grass from the PO there, little bit of bubbling on the stiffener plate but otherwise in really good shape. Spindles were dry but have responded to greasing the idler bearing is good (really unusual for me as almost every customers machine I work on needs idlers).
The reunion/marriage of the deck back to the tractor! I replaced the front tyres here also was a fun night.... (had the rears done earlier at work)
So, I have my hubcaps back and I have polished them back up again but they are not the same was they where sadly - I will take real photos with my camera if the weather holds. I did forget one thing, the return spring on the PTO lever. I was really stoked when I started the deck up and it was whisper quiet, no vibration through it also - very pleased with my tractor!
Edited by Blue Delta
  • Excellent 2
Racinbob
Wow! I didn't realize this thread was started over 3 years ago. Glad you revived it. I'd say that tractor has found a good home. :handgestures-thumbupright:
peter lena
welcome blue delta, glad to see your recovery of this great unit, on your paint issue, from the initial view ,  i would buff it out , where you can , maguires   paint cutter with a small 6 " palm buffer  will bring it out, then use a paint spray on detailer to easily maintain /  enhance it . pete
tom2p
the 'hunting' or surging is often a sign of intake issue ... air intake / manifold leak ... carb ... maybe valve ?
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The kit operates very simply and similar to modern tractors. When the pedal is pushed forwards the tractor will move forwards. When the reverse pedal is pressed downwards, the tractor will moved in reverse. If the operator takes his foot of the pedal at any time, the pedal will automatically center itself and the hydrostatic transmission will return to neutral (stop). This enables the operator to use both hands on the steering wheel or one hand on the wheel and the other operating an attachment like a snow blower, plow, etc.
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      The pedal kit fits the following series tractors with Eaton hydrostatic transmissions: C-1X5, 300, 400, 500.
      My kit can be adapted to older hydrostatic tractors with the Sundstrand transmission, however, you will need to find an updated hydro cam commonly found on ebay. Message me for more information.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      If anyone has any questions please feel free to PM me or post your question here and I will be glad to help. Or you can email me at mattdarling02@hotmail.com.
      Thanks!
      Below are pictures of the complete kit and the pedal installed on the tractor. Some modifications have been made since these pictures were taken. For example, the reverse pedal is now cast in aluminum instead of the steel pedal shown below.
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
