kcuttuck
C121 will not crank
kcuttuck
My 1978 C121 will not start. It will not crank over. The voltage at the battery post on the key switch is 12.3 volts. When I turn the key to the run position the voltage at the battery post on the key switch drops off.
I tested the clutch switch. good
Replaced the key switch.
Seat switch is bypassed.
I am suspecting the PTO interlock switch but I have no idea how it works and how to test it. I am very mechanically inclined but I have never seen a switch like that before.
Help Please.
Matt
953 nut
Voltage dropping off is an indication of bad connections. Before you start replacing anything, clean and tighten all electrical connections. If the problem remains you can take a small jumper wire from the battery positive to the small terminal on the solenoid which should actuate the solenoid and starter.
kcuttuck
I replaced the wire connectors for the key switch. What other connections do you suggest I clean?
953 nut
All of them! The battery cables (+ & -) at both ends and the cable from the solenoid to the starter. Any corroded or loose connection anyplace in the electrical circuit will result in voltage drop.
oldredrider
The C-121 is a cradle motor and has an extra ground wire on the cradle. Make sure it is connected well.  I've seen vibration of the motor take a toll on them.
kcuttuck
I found a bad amp meter. It showed power though it till there was a draw.
Thanks for the help.
gwest_ca
You can bypass the ammeter by placing both wires on the same terminal. Disconnect the negative battery cable before you do to prevent an accidental short.
A more economical repair is to replace the ammeter with a voltmeter and it will give you more useful information. A voltmeter needs to be powered by the ignition circuit plus a simple ground to the chassis.
Garry
  • Similar Content
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • 953 nut
      By 953 nut
      I have a few basic electrical system diagrams that are helpful in understanding how the wiring system works. They are not specific to any particular tractor and do not include safety switches. All use the 5 post ignition switches 103-991 for Magneto and 103-990 for Battery Ignition. I failed to include fuses in the Starter Generator drawing, this is an over-site and I would encourage fuses be used as shown in the other two drawings.
      Hope this is helpful.
      Magneto Ignition system with electric start and solenoid.
      Battery powered ignition system with points, condenser, solenoid and electric start.
      Battery powered ignition with solenoid, points, condenser, Starter Generator and a mechanical voltage regulator.
      We have uncovered a shortcoming in the factory  wiring diagrams for S/G battery ignition systems with a four terminal voltage regulator. The wire from the regulator "Gen" terminal to the S/G  "A" terminal was omitted. This drawing should clear that up.
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • bkarp@roadrunner.com
      By bkarp@roadrunner.com
      my magnum 12 kohler all of a sudden is blowing oil out of the carb. if rings are bad should oil be blowing out of the muffler.thanks for any help brent
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
