TIMOTHY McCLELLAN
1980 W.H. 310-8/TAIL LIGHTS/REFLECTORS
TIMOTHY McCLELLAN
JUST HAD MY 310-8 PAINTED  THE REAR REFLECTORS WERE CRACKED AND BROKEN.WHERE WOULD I FIND THEM ?
WVHillbilly520H
Tractor Supply ,Advance Auto Parts, Wal-Mart ect all sell the complete actual working tail lights and/or just the reflectors, if you go the working tail lights you will have to tap into your head light wiring to make them work, pics of the shelf tag from TSC and the new lights I bought from Advance Auto,found them cheaper at WM later , Jeff.
TIMOTHY McCLELLAN
HEY Jeff thank you I got at TSC PERFECT
V-Four
Hi,
Can I ask if the ones you got at TS are the exact size as the originals?
I got a 312-8 that's missing 1 tail light, but I guess I will replace them both, as the old one that is there is, well, old looking.
Thanks.
WVHillbilly520H
11 hours ago, V-Four said:
Hi,
Thanks.
Yes ,the ones from TSC, Advance Auto, and Wal-Mart are the exact same size, Wal-Mart was the cheapest at $2.99 ea and a white base as well as the TSC pieces, the Advance 1s are black based and $3.99 ea, also they have just the reflectors too if that's what you got and just want to replace the lenses, pretty sure most auto parts stores should have them in the lighting or trailering sections, I took my old one off and with me to match it up, Jeff.
  • Similar Content
    • ebinmaine
      By ebinmaine
      Well everyone, this is going to be the First time I've disassembled a Whole tractor to repaint and refresh a few things.
      My 74/75 B80 is running good and seems to be what I wanted in a tractor so I'm going to pretty it up a bit this winter.
      No implements, just the tractor.
      I'm going to do a general degrease and clean up and spray can finish.
      What are ALL the little things you DO, or wish you you were told, or things to look out for?
      I have waiting to be installed:
      New brake lining, rear wheel seals, some knobs and stickers...
    • TIMOTHY McCLELLAN
      By TIMOTHY McCLELLAN
      Need to know PTO belt length for 1990 310-8 36 " Rear Discharge mower deck !
