bizzo15
PTO clutch temperature
bizzo15
Hey guys, so the other day I got one of those infrared "contactless" thermometer the other day as an amazon deal of the day.  Tonight I mowed my lawn and when I pulled the tractor back in the garage I decided to shoot the thermometer at various parts of the tractor and I noticed the PTO clutch seemed to be much hotter than normal.  It read as high as 190F, that seems a little hot to me.  Is it normal for them to get this hot or am I looking at a failure of the clutch?
953 nut
:twocents-02cents:           190F isn't real hot. The crank shaft dissipates some of the engine heat and the magnetic coil is drawing about ten amps witch is 120 watts of power, about the same as a large light bulb. There is no cooling fan or other heat removal mechanism around the clutch so I guess after mowing the yard that would not be excessive.
clip
My clutch sits right below the exhaust on the 16hp Briggs, most of the PTO linkage gets very hot from that too. 190F isn't too bad, you should be able to notice that burning brake/clutch smell when it starts slipping.
Pollack Pete
If it ain't broke,don't fix it.I learned a long time ago to stop looking for problems.......the problems will find YOU soon enough. Mow your lawn.Put your Horse in the garage.Open a cold beer.Enjoy.
TDF5G
I got one on sale from Harbor Freight a couple of years ago and it is fun to play with. :rolleyes:
bizzo15
Hahaha there's a lot of truth in that and I do enjoy cold beer, I'd rather take care of a problem though before it becomes catastrophic.  The consesus here is that temperature is nothing to worry about, so I won't.  By the way, I see your from Stillwater, what a beautiful area, I love riding snowmobiles in that area during the winter months.
Yes it sure is, it's amazing the uses you can find for it.
  • Similar Content
    • cJ_3D
      By cJ_3D
      Hey all!
      Replacing the drive belt on my 252-h. Anyone know the torque specification for the center screw when I put this pto clutch back on? I know it was on there tight it took a minute for the impact to break it loose. Thanks!
      CJ
    • the jeep driver
      By the jeep driver
      My daughter was using the Wheel Horse rider to mow, I was push mowing.  She drives over to me and says, "Dad, the blades aren't turning." I look at the mower, she's got the blades engaged (lever forward) but nothing is moving.  I disengage the blades, and re-engage... nothing.  No movement from the belt nor clutch.  Then I notice the smell, and look closer, the belt is so hot is melting on the clutch.  Or rather, the clutch is so hot it's melting the belt.  Melting occurred.
      While the clutch is disengaged, I can spin the clutch freely; and whilst it's engaged, it won't move.
      So, what did I do now?  Peter told me to lube that needle bearing, but I couldn't find a write up/how to anywhere, so I was putting it off until after the leaves were done falling in the Fall.  I haven't taken anything off yet, other than the pins that hold the pinion and such, and the little brake pad.  I see there are two snap rings, assume they come off, and then the assembly slides out as a whole?
      Some pictures of the clutch, can anyone tell if it's usable from them?
    • decvt79
      By decvt79
      My 1999 270H with 48” deck is having an issue getting power to PTO.   Checked PTO with jumper to battery and it worked fine and I’ve actually been cutting grass using the jumper for awhile.  I checked power from PTO switch to PTO and there is none.  I checked PTO switch and it appeared OK but I replaced it anyway and still no power to PTO.   Then checked brown/tan wire leading to switch and there is none.   Could the issue be the NMIR module and is there a good way to check it.  If bad, where is the best place to get a replacement and do other brands/models have NMIR a modules I can use.    Also, would suppling battery power directly to PTO switch and bypassing NMIR result in switch working.
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
