mikekot3
Hello
I want to buy the seat mentioned in Martin Howard's 416 adventures. I tried to contact him but he is not able to receive emails through red square.
I have a 1993 WH 416-8 tractor. He used a KM UNIPRO 123 seat from www.turfseats.com
 Which seat switch do I use on the replacement seat? My used my FLUKE 88 dvom in auto ranging mode to test the original seat switch. With the
seat switch disconnected I get a ohm reading and O.L when I sit on the seat. I am thinking that tells me
that the seat is Normally OPEN.  Am I correct in this? Did the KM seat switch come with a pigtail for wire it up?
If not how do I install the switch? Where did you get the seat rubber bumpers for the swing up seat base? I believe they were black or grey.
Also I installed a Briggs and Stratton Vanguard v-twin 23 hp engine swap kit from small engine warehouse.
The hour meter does not work any more after replacing the swapped in engine. I was thinking that a aftermarket hour meter/tach from esitest.com would
work. http://esitest.com/329.html
My other question is that I can only start the tractor by turning the key and also turning the light switch ON to engage
the starter motor.  I am thinking one of the power wires in the white AMP engine harness connector is in the wrong pin position as I had to
replace the connector.
Please advise,
Michael Kotarba
mkotarba@hotmail.com
Edited by mikekot3
typo
Don1977
We need pictures of that 423-8. Sorry I can't help you with the wiring.
gwest_ca
Here is the detailed wiring diagram but it has a mistake. It shows battery point and condenser ignition in the "Spark Circuit" diagram which is not correct for the original motor.
The ignition on the B&S engine is self-powered and the lone ignition wire is simply grounded to shut the engine OFF. Do not allow any battery power into that ignition wire - it will burn up the coil.
No doubt you have replaced the igntion switch for one designed for magneto ignition. Depending on the switch used you may have to use the accessory terminal to power the hourmeter and other gauges.
Garry
mikekot3
Hello Gary,
In regards to the B & S engine the hour meter I am considering is self powered by a quarter sized battery. Should I not connect to the coil ignition wire?
I have not changed the ignition switch at all prior to and after the engine swap.
gwest_ca
I believe those tachs have a wire that gets wrapped around the spark plug wire - yes? That's OK.
I'm talking about the small wire that comes from under the metal tinwork probably with the stator wires for charging. That is the one that gets grounded to shut the engine OFF. Not connected the ignition works.
What is the model number and serial number of your tractor? The original Onan engine should have had battery ignition.
Garry
mikekot3
Hello Gwest,
Here is a picture of the ESI tachometer and hour meter . It appears it taps into a circuit and not a inductive probe. My tractor is a WH 416-8 which had a onan p216 engine. The model is 73420 and the serial number is 5900434. I have not found a schematic for the 1994 416 tractor. I did find one for 1991 model year 416.
Most diagrams I am used to mark the switch as N.O. normally open or Normally closed N.C. The diagram does not show that I believe.
Thank you for your advice.
Mike
gwest_ca
Your tractor is a 1995 model. Here is the operator manual
Here is a good detailed wiring manual. It is the same file I linked you to earlier if you downloaded it.
Garry
953 nut
Gary, the ignition shut-off wire may be connected to the throttle control plate depending on the application that the B&S came from. Lots or aftermarket motors have the kill switch tied to throttle function.
mikekot3
Hello Gary and Richard,
Thank you very much for the feed back on My Wheel horse tractor. I assume since the onan engine sticker said made in 1993 that was the year the wheel horse was made also.
You folks are a great resource for knowledge for Wheel horse equipment.
Edited by mikekot3
mikekot3
Hello Gary,
The link for the operator manual seems to be broken.
Thank you in advance.
Mike
gwest_ca
  On 5/13/2016 at 2:46 AM, mikekot3 said:
Hello Gary,
Mike
Sorry about that. Try it now.
Garry
  • Similar Content
    • rustyedge1
      By rustyedge1
      Looking at this Ferris seat and wondering about the issues I may encounter in trying to switch out entire seat on the 417 or even if it can be done ?
      Any info would be appreciated and thanks in advance.
    • Monstrosity
      By Monstrosity
      Show off what your doing from the seat of your Horse!!! Fixed up a mowing deck for the 1277 and put the plow on the C1014. Getting ready to level a topsoil pile and going down the block to mow the small park to test the mowing deck out.
    • Bill D
      By Bill D
      I have a GT1800 that I have swapped an M14 into.  The original drive belt is too long for the Kohler.  I tried a 7473 belt and that was too long.  I'm guessing I need an 81" belt.  Does anyone know for sure?  I'm thinking it should be the same length as a 314H?   I'm trying to avoid multiple trips to TSC with the price of gas.  Yes, I do have the correct hydro pulley on the Kohler.  Thanks.
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
    • 702 timmy
      By 702 timmy
      looking at upgrading my c-100 10 horse to a 16 horse. Can a k-341 fit into a c-100 space?  Any complications? Thanks  timmy
