timmy b
1987 418-A Question
timmy b
I am looking at what appears to be a 1987 418-A...however it has a Kohler 17HP Series II engine...is this a typical engine for this unit or should I assume it is not the original engine?
farmer
There is a pic of that tractor in the gallery for you to compare with, sorry not sure about the engine.
gwest_ca
Perhaps the engine numbers will fall here
Garry
N3PUY
I think that if it is a "418" tractor then the motor should be a "18HP" motor.
timmy b
Garry
Thanks Gary...yes it does...engine is a KT17QS-24363...however the tractor is a 418-A...I thought that was unusual...I'm thinking the 17HP engine is not the original engine?
I
ericj
they also made a 417-A , perhaps it is a 417
eric j
timmy b
Thanks Farmer...
I agree...
eric j
Understood Eric however hood decal says 418-A and engine is definitely 17HP...so either the hood was changed or the engine was changed haha...
pfrederi
The only significant difference between a KT17 Series 2 and  Magnum 18 is the ignition system... How they got the xtra 1 hp I do not know.
Edit :: looked at Kohler Svc Manuals for KT 17 and M18 both are 42.18 cubic inch displacement.
Edited by pfrederi
BESTDOGEVER
418 should have 18hp magnum  engine  the  kt series would be on the 417A so engine could be a replacement
timmy b
Thank you pfrederi for the info...
I agree Bestdogever...thank you for your input...
19richie66
Either way, that machine should be a beast. Mine pulls like a horse( pun intended). I love using it around the yard. Run the model number to see what the tractor should be. If the tractor has pionts and a coil, it is not original to the 418-A. The hood should have louvers in the top of it also. Should have an Eaton 1100 rear in it also. I'd roll with it either way if the price was right.
:ROTF:It's in the decal.
timmy b
Still tossing it around...this horse would grow my herd to 4...just saw it and got feverish haha
  • Similar Content
    • drewd
      By drewd
      I am working on a 1987 416-8 that I picked up a couple of years ago.  I bought it from the widow of the PO.  It was obvious that it had been stored outside in the past and PO had repainted etc., but this machine had seen some use for sure!  Motor sounds good and the tranny does not make noise so I am fixing it up a bit for a worker at my camp.
      I am working on the manual lift linkage now and need some advice on how far I can or should take this.  The spring in the handle was frozen when I got the machine but I got it lubed up and working again.  However, it's a bit lazy on the uptake.  Also, there is some play on the handle side of the lift.  With the weak spring and sloppy bushing on the same side the lift will not lock in place once lifted.  You can get it to catch but if wiggled a bit it simply drops.  PO told me they just left it down.  I cannot get the handle of the shaft.  I drove the pin out and am soaking it now in hope some heat will help after a day or two.  I did get the push lever out and picked up a new spring.  I would really like to replace the bushing on the handle side if possible.  The sheet metal does not look out of round and neither does the bushing but you can see that the bushing is slightly smaller than the hole in the metal so it has play on that side.  Neither the metal or bushing looks uneven from wear. The bushing on the right side is pressed in the sheet metal pretty well and is still tight on the shaft.  If I cannot get the handle off the shaft without damage to the sheet metal I was thinking of trying to work in a shim around the bushing to take up the slack.  Has anyone had this issue?  Any ideas?
      Thanks!
