DorkFish
Amazon replacement carbs
DorkFish
Has anyone ever used one of these replacement Kohler carbs from Amazon?  Went ahead and ordered one for my 16 HP K341.  The throttle shaft on the old one has so much play that I'm surprised the thing even runs at all.  I've heard plenty of good reviews and also plenty of jeers claiming they are cheap and don't work as well.  Looks like an exact copy of the Kohler carb.  I guess we'll see for certain tomorrow when I get it put on...
rmaynard
I have used a lot of BBT products. They work great. I have not used a BBT carburetor, but I have used several other Chinese carbs on K241's. They all worked great. I am not sure if BBT uses SAE hardware, but I would check to see if the screws and shafts and needle valves are all made to SAE specs or metric. The carburetors that I bought off eBay were all SAE and that was stated in the description.
roadapples
I`ve got the exact same carb. but haven`t installed mine yet either.. let us know how you make out..
bds1984
I bought the same carburetor for my C165 and have no issues with it other than I had to adjust the needle and seat because too much fuel was coming in and flooding out the carb.  But, it starts easy and runs great.  I also bought on for a M12 on my 312-8 and had nothing but good luck with it.
DorkFish
How do you adjust the seat?  I've never had one of these Kohler carbs apart.
bds1984
I should have probably said I adjusted the float and needle so they close against the seat and not just continuously let fuel flow in.  With the way the C165's carb was I had to slightly bend up the tab on the float that holds the needle.  The carb on the M12 I did not have to so maybe it is a quality control issue.
DorkFish
Yeah or possibly just bent from being jostled around by the mailman.
bds1984
Anything is possible with the long journey from China...
rustykan
I purchased mine on Amazon also, but do not remember the brand. Only problem I had was the choke was not oriented correctly and I had to remove and reinstall it. Not a big problem though, considering the price. I think I only paid around $50 for it a couple of years ago.
illinilefttackle
Working on a 1990 -312-8 with Magnum 12 engine- carb flooding- Amazon wants $ 113 for this carb- Thoughts? Rebuild kits with float are $83- Thanks- Al
  • Similar Content
    • Gravely Horse
      By Gravely Horse
      I’ve got a 520xi with a ch20 kohler. It has 982 hours. It runs fine, but after seeing this valve train kit on eBay, I was wondering if there is any harm or need to throw one in it. Any one have insight into this?
    • bigbuck
      By bigbuck
      I had a fire in 2019 which destroyed my pole barns and some wheel horse tractors and parts. i'm looking for someone who can use the engine that went thru the fire. It is not pristine but there must be some usable parts
      please call George at 517-499-5678 for more info.
    • CasualObserver
      By CasualObserver
      Owners manual for the two cylinder snowmobile engines.
      12 pages 1.38MB
      1970 399 Safari snowmobile model 9-0041 - 2-cylinder
      1970 440 Safari snowmobile model 9-0051 - 2-cylinder
      1972 399 15" Safari snowmobile model 9-0042 - 2-cylinder
      1972 399W 22" Safari snowmobile model 9-0310 - 2-cylinder
    • CasualObserver
      By CasualObserver
      Owners manual for the Single cylinder snowmobile engines.
      12 pages 1.33MB
      1970 295 Safari snowmobile model 9-0011 - 1-cylinder
      1970 309 Safari snowmobile model 9-0021 - 1-cylinder
      1970 309W Safari snowmobile model 9-0061 - 1-cylinder
      1970 355 Safari snowmobile model 9-0031 - 1-cylinder
      1972 335 15" Safari snowmobile model 9-0032 - 1-cylinder
    • Jeff-C175
